Solvent, kerosene
Results 1 to 10 of 16
    Junior Member Porcupine's Avatar
    Cincinnati, Ohio
    16
    Several places in the manual talk about cleaning things with "solvent." I'm new to engine maintenance. What kind of solvent are they talking about? (the more specific, the better, please.)
    Also, regarding cleaning the chain with kerosene. I've never bought kerosene. Is there more than one kind? Where do you guys get it?
    thanks
    Mark
    Mark
    2007 TW200
    Senior Member chevyluver's Avatar
    Lebanon, OR
    208
    I've always went to my local AutoZone or Napa and bought a gallon of cleaning solvent. I dont remember what brand it is, but I think they're all basicly the same. As for kerosene I think there's only one kind, I go to my local Bi-mart and buy it in a 4 gallon bucket, I use it for cleaning parts and running my shop heater in the winter. I hope this helps.
    1999 TW200 Mods- Fishing rod holder, Tail bag, handlbar risers, and soon to be JimboSheild
    Senior Member Woofhound's Avatar
    Federal Way/Cle Elum Wa.
    369
    No 2 diesel is basically the same as kerosene as far as cleaning. Kerosene and No 1 diesel are the same thing. Mixing a little ATF in with the diesel will also help for cleaning. ATF has a high detergent content
    2009 WR250R
    2005 V-Strom
    1993 Shadow 1100 with Ural sidecar
    2008 H-D Ultra Classic
    2009 Zuma 125
    2004 Zuma 50
    2000 WR400F
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    I got a solvent tank a couple of Christmas's ago. When I asked about what to purchase, a couple of folks suggested 'Stoddard Solvent'. I went to a petroleum dealer and asked for Stoddard Solvent. They indicated it ran $8.00 a gallon. Since I asked Santa for a 15 gallon tank, I was shocked. I purchased 5 gallons and filled the tank with bricks to minimize the volumn. Gerry
    Take care my Friend.........
    Member Fourcycle's Avatar
    SE Michigan
    78
    For removing oily grime and the sort, I like Citra Solv full strength. It's expensive but you don't need much. It rinses off with water and leaves you smelling like ...citrus. I've been using it for about 10 years now and all those petrol based cleaners are a thing of the past for me! I rebuilt a R60/2 BMW, a CX650C, the TW200 in my avatar, lots of other smaller projects and I've only used about a gallon in those ten years.
    If your only tool is a hammer
    Everything looks like a nail
    Cincinnati, Ohio
    16
    Thanks for all the great info, guys. Much appreciated.
    Mark
    2007 TW200
    Senior Member darnold87's Avatar
    Salem, OR
    908
    I agree w/ everyone about using specific cleaners rather than solvent. I'm a chemist and work with many of the solvents you can buy at hardware stores (MEK, Toluene, Xylene, Naphtha, Acetone, etc). You don't want to use those on your bike as they are overkill. I usually stick with Simple Green, Purple Power, and sometimes good old WD-40. Worst case scenario, sometimes those strong solvents can be helpful getting the really tough stuff off (like old chain lube grime on the swing arm).
    As for parts cleaner tanks, the stronger (harsh) chemicals are so much more efficient than the eco-friendly ones. I use a 2:1 blend of Mineral Spirits and Butyl Acetate... that will pretty much dissolve grease and paint right off of your parts.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    Quote Originally Posted by darnold87 View Post
    I've been using just straight kerosene, with an old toothbrush to clean my chain and parts. Works great! I've got 18,000 miles on my R6's (factory) chain from doing this for 5 years
    Salem, OR
    908
    Kerosene is a pretty weak solvent, so yeah, that's another 'safe' one to use on the bikes... It's available at most hardward stores and is usually labelled "Kerosene K-1".
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Member dawgs's Avatar
    Aug 2010
    64
    Quote Originally Posted by mrgizmow View Post
    Stoddard solvent, mineral spirits, white spirits, dry cleaning solvent and paint thinner are all the same solvent.
    It was originally called Stoddard solvent by the dry cleaner that developed it W.J. Stoddard.
    It is the main ingredient in WD-40.
diesel vs kerosene for solvent
is stoddard solvent the same as kerosene
kerosene compared to stoddard solvent for cleaning
kerosene solvent
kerosene wick cleaning solvent
lubing the swing arm tw200
msds sheet tekstyle formula ts-3
petroleum based solvent tw 200
solvent kerosine
stoddard solvent vs kerosene
where to buy toluene cincinnatti ohio
where to purchase stoddard solvent in nevada
