Hand Grip Size
Results 1 to 10 of 11
Thread: Hand Grip Size
    Junior Member jim1504's Avatar
    Nov 2010
    Dallas
    28
    Can anyone tell me what grip size I need for the both grips (throttle & regular grip). I did a search and someone indicated they were different sizes but did not specify what exact size they are. Thanks for any help.
    Ephrata, WA
    1,125
    I don't know of any grips that are actually sized differently, but if they are, the bigger one goes on the throttle side of course. Just get ones for 7/8" bars.
    1990 TW200
    Aug 2011
    Cayce, SC
    3,109
    Most grips are made for 7/8" bars. Thats what you need. The throttle side will have a larger interior diameter.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Member -Jake-'s Avatar
    Feb 2012
    81
    yep. just put some pro grips on mine and one had a bigger ID for the throttle.
    Nov 2010
    Dallas
    28
    Great thanks guys. I guess one is probably just slightly larger.
    Thanks
    Quote Originally Posted by -Jake- View Post
    Aug 2011
    Cayce, SC
    3,109
    Those pro grips are the best i've found yet. And they last! I went through three sets of protapers until I spotted these.
    Ephrata, WA
    1,125
    I like these Pro Grips
    Put a set on mine and my Dad's TW last year. Very comfortable. I have black and he has blue. The blue matches the TW blue well.
    1990 TW200
    If your bike is stock, you need grips for a motorcycle with 7/8-inch handlebars.
    ATV grips are both the same size because they don't have a throttle tube. Motorcycle grips will have one grip hole slightly bigger than the other to fit over the throttle tube. Some big street bikes have 1-inch handlebars instead of 7/8-inch, and require bigger holes in the grips. Now, to really confuse matters, I run 7/8-inch throttle side grips on both sides because I've added shrink wrap to the left side to insulate the grip heater from the grip warmer. The throttle tube provides the insulation on the throttle side.
    Nov 2010
    Dallas
    28
    Thanks qwerty, I ordered the 7/8" grips!
    Desert, SoCal
    7,369
    The Progrips that Rainman has linked to are longer than most other grips and are meant to be cut to length, so don't panic if they seem too long when you when you install them. They were meant to be universal and if you use the cut lines they'll fit almost any situation perfectly.
    There are handydandy cut lines on most models of Progrips. So if you're running handguards cut the outboard ends off at the cut line. I usually use an Xacto knife. On the throttle side you'll find two "donuts" with cut lines on the inboard side of the grips. On most TW's you'll want to cut off the larger of the two donuts on the inboard side and the very end on the outboard side. If you're running handguards AND a throttle lock cut at the first safety wire groove, etc.
    You'll want to get the length right, particularly on the throttle side. If you just "scrunch" them onto the throttle tube as-is your throttle will likely bind.
  1. Hand guards
    By rfsx15 in forum Technical Help
    Last Post: 02-28-2018, 02:25 PM
  2. Slime saved the day in my Duro Power Grip
    By JS5owner in forum Technical Help
    Last Post: 05-24-2013, 05:34 PM
  3. Tandem grip US $14.99
    By UPS in forum TW200 Classifieds
    Last Post: 11-01-2012, 09:44 AM
  4. Duro power grip 26x8x14
    By captncrunch in forum Performance and Customization
    Last Post: 09-08-2012, 09:42 PM
  5. Hand protectors
    By mac1 in forum General Discussion
    Last Post: 08-10-2011, 04:29 PM
are there different size atv hand grips
diameter throttle grip
grip size on tw200
grips for yamaha tw200
motorcycle grip length
motorcycle grip sizes
motorcycle grips 2012 yamaha tw200
tw200 best handgrips
tw200 grips
tw200 handgrips
tw200forum hand grip
tw200forum install hand grip
