oil leak from where
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By elime
Thread: oil leak from where
    Junior Member jerz006's Avatar
    Aug 2011
    tampa fl
    25
    i have a new to me bike 96 tdub i noticed a small leak earlier now i parked the bike on concrete now its a huge leak on the right hand side im wondering if its a base gasket leak or worse can any one help me by telling me what to expect the bike runs smooth and besides this all has been good this is my second tdub im officially addicted and hope i can fix this problem because i want to ride with no worries thanx in advance
    Senior Member Ayers Garage's Avatar
    Jun 2012
    125
    You're just going to have to get the engine clean and find the source of the leak. A few words on the internet can't paint enough of a picture.
    Things on the right side could be the kickstart lever seal, the side cover gasket, the sight glass, oil filter cover. Or it could be coming from just about anywhere and running along the skid plate and dripping out somewhere else. It could be the drain plug.
    Ephrata, WA
    1,125
    I've heard of a trick on this forum that involves cleaning your engine and then sprinkling powder on the motor where you think the leak is coming from. The oil will show on the powder. Like Ayers posted, the leak could be coming from anywhere. It could be coming from the oil filter cover, but won't show until it hits the ground.
    1990 TW200
    6,961
    Check the o-ring on the filler cap.
    Climbers TW200 likes this.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    All of the above is good advice. Here's another possibility.
    Aug 2011
    tampa fl
    25
    ok i found the problem hopefully this is the only leak the bottom of the crankcase cover was previously repaired with some kind of jb weld. At first the leak was only a couple of drops but now i recall going over a small jump and it could have loosend the weld more it seem as if i replace the weld with jb it would keep reoccuring so im going to get it profesionally welded it hope fully it wont cost much
    Senior Member bbagwell's Avatar
    Salem, Oregon
    421
    A reputable bike shop owner told me about using JB weld. I think the trick is to really prep and sand the surface lightly. I think you are on the right track though to get a permanent fix.
    Bryan Bagwell
    1995 Yamaha TW200
    1983 Toyota PU
    2002 Suzuki Grand Vitara
    Jun 2012
    125
    You'll need to remove the cover and clean it very well before you repair it. Any oil residue will undo your efforts.
  1. Oil Leak
    By ldw72120 in forum Technical Help
    Last Post: 02-25-2013, 08:49 PM
  2. Oil Leak
    By Senior Dirt Dog in forum Technical Help
    Last Post: 08-03-2012, 09:48 PM
  3. Oil leak...
    By xdac in forum Technical Help
    Last Post: 10-27-2011, 12:32 PM
  4. Oil Leak
    By B-dub in forum Technical Help
    Last Post: 08-09-2011, 01:19 AM
  5. Oil Leak
    By Mike Mecredy in forum Technical Help
    Last Post: 07-19-2011, 06:15 PM
tw200 oil leak
tw200 oil on top and side of mot
