Stock muffler question
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Gerry
Thread: Stock muffler question
    Junior Member Adam38654's Avatar
    Jul 2012
    14
    Is the factory muffler supposed to have any baffles in it besides the spark arrester screen and little propeller blade looking thing welded to the back of the end cap? Mine is hollow like the insides burnt out but I don't see how that could happen in 1700 miles. I would like to make mine quieter but I don't see we're I could put any packing as there is no core pipe.
    Desert, SoCal
    7,369
    The stocker is about as quiet as a muffler gets.
    If yours isn't, there's something funky going on.
    There is no packing, nor is any needed. It's purely mechanical.
    The baffle/spark arrestor with the screen and the propeller thingy should be as you've described. If the are no openings, burned out spots or cracks in the stainless that part is fine.
    Looking down into the muffler with the baffle removed you should see a "nosecone" at the far end of the inner tube. The nosecone should be solid and there should be two small holes in either sidewall about 1/2" in diameter. There should be no holes, openings or daylight otherwise visible except to the sides.If the bike were run lean enough for long enough it's possible that either the nosecone could be burned off, cracked or the holes enlarged by heat.
    Other than that there ain't a danged thing that can go wrong with one.
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    ANy body hack or cut it to think they get more performance ?
    Jul 2012
    14
    Does anyone have a pic of the muffler inside? Someone must have cleared the inside of mine out or something.
    http://www.stadiumyamaha.com/pages/OemParts?aribrand=YAM#/Yamaha/TW200_-_TW200R_-_2003/EXHAUST/TW200R_(2003_MOTORCYCLE)/EXHAUST_(TW200R_-_2003)
    Just the end cap and the attached baffle/spark arrestor. Yamaha did a good job on engineering the exhaust on the TW. Light, quiet, and stops sparks.
    Jul 2012
    14
    I guess its just loader than I expected. I was afraid that ring of carbon half way back used to be a baffle and it almost looks like a piece of fiberglass in the back that you cant see in the pics.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    They are quiet, but I wanted to see if I could mute the "putt, putt, putt" a bit. I fabricated an add on silencer. Seems to work pretty good and did not impact performance as near as I can tell. I still manage to go fast enough to fall over .. Gerry
    r80rt likes this.
    Take care my Friend.........
    Jul 2012
    14
    I would like to make a packed core like that inside my muffler but at this point I think I am just going to go with a DG oval with quiet core and spark arrester.bassically the same thing and looks better. It can't be louder than mine is now and I like the lower sound.
  1. Stock muffler for sale
    By patrick007 in forum TW200 Classifieds
    Last Post: 06-05-2013, 01:06 PM
  2. stock muffler wanted
    By bronco in forum TW200 Classifieds
    Last Post: 06-12-2012, 09:55 AM
  3. WTB: stock muffler for an '04 (NY)
    By 98940 in forum TW200 Classifieds
    Last Post: 04-26-2012, 09:48 PM
  4. WTB: Stock Exhaust/Muffler
    By panamacolin in forum TW200 Classifieds
    Last Post: 06-23-2011, 09:01 AM
  5. stock muffler modification
    By tripleted in forum Performance and Customization
    Last Post: 03-09-2011, 07:10 PM
remove tw200 stock baffle
