Burnt red wire
Results 1 to 5 of 5
Thread: Burnt red wire
    Junior Member snakefoot's Avatar
    Jun 2012
    Washington St
    15
    About 6 inches forward of the battery, a red wire (one of 4 wires in a harness) is burnt and throwing smoke/spark. I noticed a patch of soot under my seat during regular checking/cleaning which lead me to the red wire where the insulation has been burt through and wire was exposed. I wrapped the spot with electrical tape. I'm a noob and not sure what this wire is for or how to resolve the issue. Any help would be greatly appreciated. The system is stock for what I can observe.
    Ephrata, WA
    1,125
    Got any pics? What does it attach to?
    1990 TW200
    Jul 2011
    1,123
    This one?
    ITCB
    Jun 2012
    Washington St
    15
    Quote Originally Posted by operose View Post
    This one?
    Yep... Thats the one. I've got shorting now if the bike is leaning or if I bounce on the seat.
    Ephrata, WA
    1,125
    You are going to need to find out whats its rubbing on and try to either relocate the wire or tie it more securely. Before you do that though, you are going to need to cut and splice in a new wire or at least put in a butt connector (if the insulation on the existing wire is gone and the wire itself is rubbing).
    1990 TW200
  1. Cdi yellow wire
    By GrantM in forum Technical Help
    Last Post: 04-29-2013, 10:11 AM
  2. How to change the spark plug wire?
    By Sverige21 in forum Technical Help
    Last Post: 05-27-2011, 08:37 PM
  3. Spark plug wire change
    Last Post: 04-20-2011, 08:30 PM
  4. Where does this wire go?
    By tok-tokkie in forum Technical Help
    Last Post: 01-07-2011, 12:21 AM
  5. Wiring Question - Where does this wire go???.
    By Grant in forum Technical Help
    Last Post: 12-25-2010, 12:31 PM
burnt red wire in millbank generator
