Lost Nuetral Light ?
Results 1 to 10 of 11
    Member Gene-st1300's Avatar
    Aug 2011
    42
    I was out trail riding and the nuetral light just sort of flickered and went out, all starting and riding functions seem find where is the most logical place to start the search for the cause ?
    Thanks
    Desert, SoCal
    7,369
    Start with the bulb itself.
    Junior Member Zahnarzt's Avatar
    Jul 2012
    North Carolina
    6
    Did you put it into gear?
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    Let out the clutch if it doesn't move its either, off, neutral, chain broke
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    like Lizrbrth said. Start with bulb and might be able to swap high beam indicator bulb with neutral bulb? I haven't done this or know if its possible on tw but Ive done this with other bikes.
    Ephrata, WA
    1,125
    Mine has gone out too. A quick trip to the auto parts store with old bulb in hand solved it.
    1990 TW200
    Oct 2011
    Eastern Connecticut
    443
    I think tw electrical voltage control poor and vibration high.
    Back in the day instrument bulbs popped all the time
    Indicator bulbs don't last on a TW, a few thousand miles at best. I switched to LEDs and no more problems for the next 38,000 miles. Just replaced the speedo illuminating LED. which went out. While I had the bike apart, went ahead and changed the 4-LED bulbs with 1-LED bulbs beacuse the 4-LED bulbs were too bright.
    Aug 2011
    42
    Ok a burnt out bulb was just to simple a issue !! now where do ya find these LED bulbs ?
    Senior Member rm_hm's Avatar
    1,619
  1. Lost key help !
    By gregor in forum Technical Help
    Last Post: 03-08-2019, 02:57 PM
  2. trouble with tail light install - DRC Edge Brake Light
    Last Post: 07-13-2017, 08:36 PM
  3. We lost a member.
    By FortPayne in forum General Discussion
    Last Post: 04-05-2013, 04:22 AM
  4. lost my keys.
    By yoter in forum Technical Help
    Last Post: 06-30-2011, 11:05 AM
  5. Lost the Spark!
    By Sharpline in forum Technical Help
    Last Post: 08-04-2010, 10:11 AM
tw 200 neutral light
