2003 TW Running Hot?
Results 1 to 4 of 4
    Junior Member 82indypc's Avatar
    Sep 2011
    Rochester NY
    20
    Well I finally was able to get my TW200R that I bought and stored last fall, out, running and on the road.
    Went over the entire thing, pulled the carb, cleaned, changed oil, etc etc.
    Went for several rides and it seem that its running hot to me. I did clean and bead blast the
    plug when I first took it out, but a week later and its still white vs tan. I do have an 8ES
    plug in it, perhaps I should try a colder plug.
    I see there is no external fuel air mixture screw on this cab to adjust, else I would go richer.
    I dont sense any overheating or fading while running, engine case see pretty hot to me.
    I am new to the TW overall but have some BW200 that are mostly getting wet when I ride those
    so engine heat was never noticed.
    Any thought appreciated.
    Cheers
    tjs
    Desert, SoCal
    7,369
    The idle mixture screw is hidden under a soft plug on the underside of the carb. Most guys report good results with it in the neighborhood of 2 1/2 turns out from fully seated as a starting point on the later CV carbs like yours.
    If you're running white do the usual checks for manifold leaks, etc. and if none are found it may be time to rejet.
    Your neck of the woods is so close to sea level that you should have a lot of latitude for main jet increases. Very few have ever found the need to up the pilot jet.
    Senior Member Woofhound's Avatar
    Federal Way/Cle Elum Wa.
    369
    my plug is real light colored in my 09, dealer recommended a 130 main jet when i bought the bike. my motor sounds like it's pinging almost all the time but the bike runs smooth. took it in to the dealer at 600 miles, they did a valve adjust which changed nothing and stated the noise wasn't normal but lots of the tw's have the noise in them. They also told me that yamaha won't pay them for exploratory work to find problems and i would have to pay if i wanted them to try to fix the noise. I guess when it blows up i'll get rid of it
    2009 WR250R
    2005 V-Strom
    1993 Shadow 1100 with Ural sidecar
    2008 H-D Ultra Classic
    2009 Zuma 125
    2004 Zuma 50
    2000 WR400F
    1996 TW200 Edmonton, AB
    590
    A bad plug will make it run hot. Before you do anything drastic try a stock new one.
  1. My New (To Me) 2003 TW200
    By TWBUSHMAN in forum General Discussion
    Last Post: 06-14-2013, 08:55 AM
  2. 2003 TW for sale
    By oldbroadbiker in forum TW200 Classifieds
    Last Post: 05-19-2013, 04:15 PM
  3. 2003 low mileage for 1600.00
    By doefingers in forum TW200 Classifieds
    Last Post: 03-11-2012, 11:12 PM
  4. 2003 TW for Sale $750 obo
    By MrClean in forum TW200 Classifieds
    Last Post: 10-15-2011, 06:37 AM
  5. 2003 Yamaha TW 200
    By gweezo698 in forum TW200 Classifieds
    Last Post: 08-27-2011, 06:54 PM
pinging tw200
tw200 pinging
