91 TW 200 will idle, then die out
Results 1 to 2 of 2
    Junior Member aduboisiii's Avatar
    Jul 2012
    Tore down carburetor and cleaned, new needle valve, seat. Float not stuck. It will start, then run for a few seconds, then die out. Will start immediately after sometimes, or needs to crank for a few seconds, then will run. Sometimes I can ride for for a few hundred feet, then die out. Petcock clean, but seems to stop getting fuel.
    Any ideas would be appreciated.
    Desert, SoCal
    7,369
    Could be a few things. The tank vent or bowl vents could be clogged. Could even be a spark/electrical issue.
    Year model and 49-state or Cali bike?
  1. idle help
    By greendub in forum Technical Help
    Last Post: 06-07-2012, 06:04 PM
  2. Dealing with idle TW?
    By drs6222 in forum General Discussion
    Last Post: 04-26-2012, 06:40 AM
  3. idle speed
    By mike m in forum Technical Help
    Last Post: 01-29-2012, 05:58 PM
  4. Fast Idle
    By ezman671 in forum Technical Help
    Last Post: 10-25-2011, 07:34 PM
  5. Return to idle...
    By Jerry Lee in forum Technical Help
    Last Post: 08-27-2010, 10:44 PM
