Quick base gasket question
Results 1 to 4 of 4
    Senior Member Larry's Avatar
    158
    Hello everyone,
    I have a question that I cant seem to find an answer for and I wanted to ask.
    I'm getting ready to replace the base gasket in my 2008 and have been looking at all the great posts. It appears to me that oil should not be leaking out the base gasket because of the huge o-ring that sits at the base of the cylinder. Does this little bit of oil that leaks come from one of the passages or does it really slip by this large o-ring?
    Any thoughts on this?
    2008 TW200 - Jimbo W/S, Rear Cycle Rack, Magnetic Drain Plug, Wally World Seat Cover, Custom JB Welded Seat Screws. (Desires - Kicker, Raised Handlebars, and Round Headlight)
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Quote Originally Posted by Larry View Post
    Hello everyone,
    Keep in mind that the opening for the timing chain is sealed only by a paper gasket. From my experience that is where the oil comes from. The newer (2010 or later) gaskets have a bead of sealant on the paper gasket which seems to make the difference.
    158
    Thanks for the information , I hadnt considered that.
    Quote Originally Posted by B-dub View Post
    Mar 2011
    Gobles, michigan
    1,824
    Make sure you tell them to order a 2010 gasket........... Very important!!!!!!!!!! OMM.
  1. wrong base gasket?
    By BoatHands in forum Technical Help
    Last Post: 04-08-2013, 10:17 PM
  2. Base Gasket Leak
    By bogey72 in forum General Discussion
    Last Post: 08-26-2012, 10:54 PM
  3. 07 base gasket leak
    By small's in forum Technical Help
    Last Post: 03-25-2012, 09:41 AM
  4. New base gasket reviews
    By kennethshaw in forum General Discussion
    Last Post: 05-11-2011, 06:10 AM
  5. Base Gasket Leak Question
    By lonedave in forum Technical Help
    Last Post: 04-26-2011, 02:49 PM
