tw 200 to 225
Results 1 to 9 of 9
Thread: tw 200 to 225
    Junior Member irrelevant's Avatar
    Jul 2012
    upstate, NY
    6
    i have a 2004 tw200 with 5k on it and it has the base gasket leak, i picked up the 2010 gaskets and was planning on freshening it up over the winter, while im in there i want to bump up the discplacement, can someone give me a rundown on whats the best way to go about it?? i already have a ttr 225 cylinder, do i need the 225 head? do i need to open up the cases to fit the 225 jug? does the cases need to be broken down to accomplish this? thanks in advance
    Desert, SoCal
    7,369
    Yes to all of the above, except the head. Your TW head will work but you might consider the 225 crank while you're at it. It's the same amount of work to take it out to 223 since you'll need to split the cases to open the case mouth.
    XT's and TTR's are 70x58.
    TW's are 67x55.7.
    223cc with the crank, 214cc without.
    Jul 2012
    upstate, NY
    6
    thanks for the reply lzrd, my ttr cyl is scratched, should i go to 71 mm or can i go to 72? what mods did ronny use to get to 250?
    thanks again
    Desert, SoCal
    7,369
    Ronny has a $troker crank and jug $pacer. I've never really liked him, but he makes a mean sammich..
    72 is fine, but it's pretty much maxed out. You can get pistons in half milimeter increments if you want to leave some breathing room for rebuilds.
    Aug 2011
    Cayce, SC
    3,109
    You will want to go up in the smallest increments possible to allow for future rebores. Going up 2mm is not going to give you more power. Ronnydog has a thread about what all he did to make his 250cc 6-speed. Great stuff! When my warranty runs out in a couple years I will be doing the same.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Desert, SoCal
    7,369
    Oh, and if you want to go stroker there's probably no need for the 225 crank. Ronny can tell you more reliably than I but I think the TW counterweights can accomodate just as much offset as the 225.
    Jul 2012
    upstate, NY
    6
    it hardly seems worth it to gain 16cc, maybe 1 or 1.5hp? thanks for the input anyway
    Desert, SoCal
    7,369
    Hit up Ronnydog or Macbig. They're probably the only active members here who have built and ridden all of the increments.
    Ronnydog first ran the 225 top end on a TW bottom end, then the full 225, followed by the 250 stroker.
    Macbig has built many different combos and has dyno charts on them.
    I've ridden Ronny's 225. Definitely a game changer. I've never ridden a 214, but those guys will be able to tell you whether or not it's worth the time/munny/effort.
    Jul 2011
    1,123
    Watch out for guys like me justifying the expense of mods in case the wife is looking!
    (Just kidding, she knows I have a problem)
    ITCB
