Difference between an DR8ES spark plug and a DR8EA spark plug
Results 1 to 3 of 3
    Stanwood,Wa
    1,887
    They're almost the same plug - according to NGK's spark plug guide the S has a standard 2.5mm electrode and the A is a 'special design' - no more info given than that!
    Read more: http://wiki.answers.com/Q/Difference...#ixzz21BC7PPr4
    Anyone have any more info. This is the plug I bought today. Should I get the dr8EA or stick with the dr8ES?
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Senior Member bcscammell's Avatar
    Oct 2011
    264
    Quote Originally Posted by goldenhtr View Post
    Read more: http://wiki.answers....g#ixzz21BC7PPr4
    Because you are unsure I would stick to the A version. There may be a specific reason for the difference in end construction of the plug that we are unaware of.
    Senior Member rm_hm's Avatar
    1,619
    Good mystery you have here
    Ngk cross ref from regular to iridium plugs shows something is afoot
    DR8EA = DR8EIX
    DR8ES = DR9EIX
    DR8ES-L = DR8EIX
    I've seen bits about special design meaning "The electrode has a small split on the end of it to help produce a better spark".
    But someone else said special design meant " If you look closely at porcelain part below the firing tip and will see how far sunken it is below the thread part".
    ES
    EA
  1. SPARK PLUG INHANCER
    By Lido in forum Technical Help
    Last Post: 03-17-2014, 07:04 AM
  2. Cracked Spark Plug
    By RainWillFall in forum Technical Help
    Last Post: 05-28-2013, 07:09 PM
  3. Spark plug
    Last Post: 05-09-2012, 08:19 AM
  4. Spark plug pic
    By mjlater in forum Technical Help
    Last Post: 03-24-2012, 05:13 PM
  5. How to change the spark plug wire?
    By Sverige21 in forum Technical Help
    Last Post: 05-27-2011, 08:37 PM
dr8ea spark plug
dr8ea vs dr8es
dr8ea vs dr8es-l
dr8es
dr8es vs dr8ea
dr8es-l vs dr8ea
dr8es-l vs dr8es
ngk dr8ea vs d8ea
ngk dr8ea vs dr8es
ngk dr8es
ngk dr8es vs d8ea
ngk dr8es vs dr8ea
