Stock jetting at 9000 feet?
Results 1 to 5 of 5
    May 2012
    Tucson, AZ
    976
    So I want to do a pretty popular local route that will take me up the back side of Mt. Lemmon, summit 9,157 feet. The FS road doesn't crest the very top, but pretty close.
    Will I be OK with stock jetting and fuel mix, or should I plan on adjusting the carb along the trip?
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Apr 2011
    Martinsville Indiana
    2,089
    You should be fine. You might have to adjust your idle mixture a little when you get up there. I rode a 98 tdub up to 13,100" and thats with the older carb which is more sensitive than the newer ones. It ran pretty good and started sputtering around 9,000-9,5000 feet but kept running over 13,000". If you are going to ride at 9,000 plus most of the time i might consider it but other than that i wouldnt mess with it.
    May 2012
    Tucson, AZ
    976
    Quote Originally Posted by Small's View Post
    I've done this route in my 4x4 Suburban before, and 80% of the trip is between 2,500ft and 7,500ft in my estimation. The final crawl to the top is pretty steep!
    Thanks for the reply.
    2012 KLR650
    - Sold
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    I think you'll be fine. I was up past 8,000 near reno (hunter lake trail) the other weekend and noticed less power but idled fine and no problems.
    Stock jet is good over 9000 feet. Even better if you drill a few 1.25cm holes in the air filter cover. I cover the holes with waterproof tape at lower altitudes.
  1. Teikei @ 8-9,000 feet.
    By trailscout in forum Technical Help
    Last Post: 07-18-2013, 07:53 AM
  2. Customizing my feet
    Last Post: 02-05-2013, 09:28 PM
  3. Jetting for 10k feet
    By -Jake- in forum Performance and Customization
    Last Post: 08-07-2012, 05:04 PM
  4. "my" jetting with DG pipe and stock airbox
    By Kirk Ross in forum Performance and Customization
    Last Post: 03-13-2012, 09:50 PM
  5. Exhaust and jetting
    By 530-TW in forum Performance and Customization
    Last Post: 05-15-2011, 09:34 AM
ktm450exc jetting 9000 feet vrs stock
tw jetting for 9000 feet
y19990 yz jetting for 9000 feet
yamaha tw jetting for 9000 feet
