Crunching sound from transmission HELP!
Results 1 to 10 of 13
Like Tree36Likes
Thread: Crunching sound from transmission HELP!
    Junior Member jarod750's Avatar
    Feb 2017
    7
    I daily drive my tw at least 70 miles a day, recently it developed a REALLY bad noise whenever I give it any gas in 1st-4th gear. If I keep the rpms really low then it does fine and in 5th it works perfect. At first I thought it was my chain hitting something, but it obviously wasn't. A friend of mine said it sounds like its trying to come out of gear, maybe a broken tooth on the transmission? I read that these transmissions can take a beating, and mine only has 8000 miles. What else could it be? I also have a parts ttr225, so if its something major I could just make it a six-speed. Any help is appreciated!
    Senior Member Miaugi's Avatar
    Oct 2017
    Alfred, On
    463
    I will assume you do check the oil level regularly and change it from time to time? As a rule noise is never a good sign for anything mechanical even if the item seems to be working fine, noise is sometimes the first sign of bad things about to happen. A good start might be have a mechanic have a look at it. If taking it to a mechanic is not possible drain the oil and look for shiny particles, almost like mini sparkles....if you see those sparkles the damage is probably already done and it will fail sooner than later. Best of luck getting her back to normal asap.
    19,069
    Crunching is not good nor self healing.
    Sorry, but I would not attempt to commute to work on it any more.
    You risk a total failure roadside somewhere far from home or a sympathetic boss.
    EDIT: Getting the transmission fixed now before it grenades might be cheaper in the long run. Alternate transportation, while a hassle, is inevitable either way.
    littletommy, maddawgj, Ken and 1 others like this.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    984
    Are there any teeth left on the front sprocket?
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Jan 2017
    Southern Nevada
    1,077
    I'd drain the oil, look for metal and when it is seen, split the cases.
    First, consider SHAG's suggest and check the counter sprocket
    Ken, Tweaker, maddawgj and 1 others like this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Nov 2010
    Frostbite Falls Ill
    2,719
    Do not ride with Chunky oil.
    Ken and littletommy like this.
    Phelonius
    Feb 2017
    7
    Thank all of you guys for the replies! I wish I could not ride it to work, but I kind of have to. I will drain the oil tomorrow to look for metal shavings. My front sprocket does seem to be a little worn down! That would be awesome if that's all it was! I'm ordering a new one right now. If it is my front sprocket which honestly it looks like it is, would it be okay to ride it?
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by jarod750 View Post
    Do you have photos? Are the teeth pulled from chain stretch? The maximum length of 15 links is 191.5 mm or 7.54 inches. If more, the stretched chain will pull the teeth on the sprockets. What is the history on the chain? How frequently lubed? How frequently adjusted.
    If not the front sprocket, possibly two of the shift forks are not laterally positioned correctly to the shift drum.
    If it is the trans, if the gears are not too badly damaged, it may be tempting to adjust and reuse, but as much work as it is, I would be prone to replacing the shift forks and shift fork guidebar.
    The fork thickness is just under 5 mm (specs in manual) and the guidebar must be true (roll on flat surface to check_
    If the trans, more likely the shift forks are worn and/or the shift fork guidebar is out of round. The drum also needs to be checked.
    HOWEVER, before getting into the trans, you can access the shift shaft/stopper by removing the side case. Whether you go deeper may depend upon what you find in the oil.
    I very much hope that it is the front/counter/drive sprocket...but if it is, it is highly likely that the chain needs to be replaced and probably the rear sprocket. Otherwise, the replacement front sprocket will not last long.
    If the trans, likely it will go until the gears do not engage.
    If the sprocket, once the teeth are worn low enough, the chain may come off and could lock the rear wheel. Best if you have some alternative to riding it, until repaired.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Junior Member PowerMax's Avatar
    Oct 2017
    East Central Ohio
    16
    I think you simply need a new chain and sprockets. It?s time.
    littletommy and Purple like this.
    '14 Yamaha TW200
    '83 Honda XL185
    '76 Honda CB550K
    '70 Triumph T-120
    Doodle Bug Hidden Content
    Feb 2017
    7
    Bought new chain and front sprocket, already have new rear sprockets. Thanks again for all the help, I probably would have taken the whole engine apart to look at the transmission. Hopefully I wont have to.
    littletommy likes this.
  1. Transmission is Whining
    By admiral in forum Technical Help
    Last Post: 02-06-2019, 06:19 PM
  2. TTR Transmission
    By DKV in forum Technical Help
    Last Post: 07-07-2016, 12:47 PM
  3. 6 speed transmission on ebay
    By sponge in forum Performance and Customization
    Last Post: 12-07-2015, 07:16 AM
  4. chipped transmission tooth?
    By decade03 in forum Technical Help
    Last Post: 06-06-2013, 11:39 AM
  5. Transmission problems
    By flailer in forum Technical Help
    Last Post: 09-04-2012, 02:35 AM
news
