speedometer light bulb
Results 1 to 10 of 11
Like Tree4Likes
Thread: speedometer light bulb
    Senior Member mekdad's Avatar
    Jan 2012
    idaho
    187
    How do you get to the speedometer light bulb to replace it? Do you pull the plug-socket thing out of the back of the speedo? just dont want to break it.
    It is a 1994.
    Thanks Ken
    You never know what you can do until you have to undo something you have done.
    Ephrata, WA
    1,125
    I was curious too, so I went out and did mine and took some pictures for you.
    I'm sure you've done it, but take off the front fairing/cowl.
    It may be easier to take off the headlight but you don't have to.
    Unscrew your speedometer cable.
    Take off the cotter pins. Be careful because they are holding on a metal washer and a rubber grommet.
    Pull the assembly up.
    You'll see where the wires go. Gently pry out the rubber plug where the wires go with your hand. The bulb is connected to those wires.
    1990 TW200
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    I replaced mine not long ago, careful with the rubber spacers, I didn't even see them when I took the clips and washers off, luckly I found them after trying to figure out why it wasn't going back together correctly.
    Also, I found the bulb at autozone if that helps.
    -Szj
    2001 TW
    Jan 2012
    idaho
    187
    Thanks guys. I thought that was how to do it, but didn't want to break the rubber plug. I will just be carefull with it.
    Thank you again.
    Ken
    Junior Member Adam38654's Avatar
    Jul 2012
    14
    Quote Originally Posted by mekdad View Post
    Thank you again.
    Ken
    Is this the only bulb. I might replace all mine with LED.
    Jan 2012
    idaho
    187
    Quote Originally Posted by Adam38654 View Post
    Yes there is only one in the speedometer. It is a Sylvania 194LL.(thats the one I put in mine)
    Mine is fixed. Thanks agian for the help guys.
    Ken
    Member canadainshiver's Avatar
    Oct 2011
    New Brunswick, Canada
    77
    Pin it?....
    1991 TW200 Hidden Content
    Jul 2012
    Wet-ern Washington
    1,404
    I too changed the bulb in my speedometer to an led...the WLED-NW5 from superbrightleds.com
    I also changed my indicator lights out to the leds today. I used the BA9s from superbrightleds.com, and I changed out my pilot box. It was one of the 2001-present changes that were made to the bike that I didn't like. I like the way the pre-2001s had the amber indicator for the turn signals instead of the green in the newer bikes. I wanted to be able to glance down and know what the lights meant by their color. The amber is better associated with the turn signals. So, I ordered a pre-2000 pilot box (Part # 15A-83568·00·00) for $18.
    Here is a link to the thread with more on the subject: http://tw200forum.co...-indicator-out/
    Here are some example pics of the different pilot boxes that I found elsewhere on this site:
    1987-2000:
    2001-present:
    It only took about 15 minutes to do the whole job. Remove the headlight cowling, remove the Jimbo shield if applicable, remove the 2 screws holding down the pilot box, remove pilot box, change the 3 indicator bulbs, check that they all are working correctly, install pilot box and screws, remove clip from one stud under the speedometer while holding up on the washer, remove the washer, remove the rubber grommet, repeat for second stud, lift up on speedometer, pull down on the grey grommet holding the bulb, replace bulb, intall all in reverse order, done! Note: on my 2004 I didn't have to unscrew anything related to the speedometer cable, it all pulled through the bottom when lifting up on the speedometer.
    I'd like to thank Qwerty, TW-Brian and Rainman for their previous work and posts on the subject.
    - Leisure Time Larry -
    2004 TW200, 13-54 gearing, Shinko 241, Race Tech Emulators, Procycle front springs, Works Performance rear shock, Emgo handguards, Luckybike mirror risers, Ken Sean DS foldable mirrors, 30mm Tusk bar risers, Seat Concepts, Kick Starter kit, Plasti-dip camo coat, Cycle Pumps, Ricochet Skid Plate, flood and spot LED pod lights, Sena, Garmin etrex 20 GPS, IMS 313114folding shifter
    Junior Member tapq's Avatar
    May 2014
    1
    This was very helpful. I found this thread by using Google. I wanted to know how to change out the speedometer bulb in my 1994 TW200, and the pictures were a big help.
    Senior Member fandango's Avatar
    Dec 2013
    long island
    309
    Damn I hope mine don't blow this looks like a betch..
  1. trouble with tail light install - DRC Edge Brake Light
    Last Post: 07-13-2017, 08:36 PM
  2. Speedometer/Odometer light went out?
    By ARAYA90 in forum Technical Help
    Last Post: 06-14-2013, 02:16 PM
  3. brake light not working, bulb ok
    By bondfast in forum Technical Help
    Last Post: 08-11-2012, 07:47 AM
  4. Wanted - Speedometer and neutral light cover
    By cohassetsteve in forum TW200 Classifieds
    Last Post: 04-25-2011, 08:22 PM
  5. bulb list
    By accor415 in forum Technical Help
    Last Post: 12-21-2010, 06:35 PM
how get bulb out of speedometer where
pilot box
replacing speedometer light bulb xt225
sppedometer
tw 200 instrument light led
tw 200 speedometer bulb replacment
tw 200 speedometer light bulb change
tw200 bulb dash led
tw200 light bulbs
tw200 replace speedometer backlight
tw200 speedometer bulb part number
tw200 speedometer light
