My uncle's TW
Results 1 to 8 of 8
Like Tree12Likes
  • 1 Post By soundguy
  • 1 Post By Fred
  • 4 Post By Purple
  • 1 Post By Purple
  • 3 Post By Fred
  • 1 Post By Badgerflorida
Thread: My uncle's TW
    Junior Member soundguy's Avatar
    Oct 2017
    My uncle's TW
    Hi All.
    We live about 7 hours apart so I can't check things, but.....
    He has a 1989 model and says the carb needs replacing.
    Does this sound correct?
    Is the carb rebuildable?
    He takes really good care of stuff and this thing is in pristine condition!
    Any suggestions are greatly appreciated!
    littletommy likes this.
    Oct 2017
    My apologies.
    I should have posted this in the technical forum.
    If a mod can move it, I'd appreciate it.
    19,019
    No problem about posting location Soundguy. However if you start in the technical help section of the forum and use the search feature using words like “Carb re-build” there is a wealth of related posts. Your Uncle’s carb likely needs cleaning rather than replacement.
    Mar 2015
    Ynys Môn
    4,630
    First up – welcome to the board
    Second up – sounds like your uncle is a good guy – take some time and go and visit (more often than you do)
    Yes, the ’89 carb can be re-built, it’s only metal, and replacement parts are readily available – but (there’s always a “but” somewhere), that depends on what’s wrong with the thing
    Jets are replaceable, but watch out for which jet kit you get, because “not all jets are created equal”. Tell that to the Chinese Airforce and they’ll laugh at you, but the jet sizes vary from manufacturer to manufacturer. What some would call a 120 may be different from what the other considers to be the same size – crazy, but true
    You could take the alternative route, and simply replace the entire carb for a new one. From Yamaha, this would cost nearly 300 bucks, but one of our members has recently come up with a perfectly viable alternative (if you are a bit creative with the rubber bits) - https://tw200forum.com/forum/performa...b-your-tw.html - and for a lot less
    But enough of this frivolity – without knowing what is actually wrong with the carb, this all becomes “theoretical”.
    Two suggestions
    Either go and visit your uncle and see exactly what’s going on (which is a good idea – see above) – or get your uncle to come on the forum and state his case
    Questions – too many
    Do you (personally) have any experience of the TW ? – the other questions can wait, or you’ll only be acting as a middle man in solving this – not a good idea
    Sorry to sound “difficult” over this, but realistically, we need a lot more info ….
    littletommy, Fred, ejfranz and 1 others like this.
    - Hidden Content
    Mar 2015
    Ynys Môn
    4,630
    And Fred is quite correct - thread moved to "Technical" - (no worries, were not anal about this stuff, were here to help) .....
    - Hidden Content
    Vacationing in the Bahama's
    17,573
    Welcome to the forum!!
    1st John 1:9
    John 3:16
    John 3:17
    19,019
    Purple, littletommy and admiral like this.
    Jun 2017
    Milwaukee, WI
    1,292
    TW carb repair/tuning can be as easy as turning the air/fuel mixture screw to the setting that is correct for your bike (no parts or special tools - just a screwdriver and a bit of your time). Or it can be as hard as replacing the carb completely. Welcome and cheers.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
