spark
Results 1 to 10 of 19
Thread: spark
    Junior Member Burns's Avatar
    Jul 2012
    Harrisburg Pa.
    17
    So as I'm trying to resurrect my basketcase, I got around to trying to checking ignition last night. Bike is missing ignition switch - no biggie.. just jumper past that.. ok. Hit the starter - turns over but no joy. Pull plug and hit starter to check spark. all I get is one, occasionally two visible sparks ... Right after I hit starter... But then nothing.. battery is new and fully charged... Any ideas?
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Quote Originally Posted by Burns View Post
    Try it with the kick starter and see if there is any difference.
    Jul 2012
    Harrisburg Pa.
    17
    Quote Originally Posted by B-dub View Post
    don't have one... mine's an '02.
    I had plenty of juice to turn it over - tried it w/ a booster pack attached, also... what is puzzling me is that it only sparks once or twice, right as I hit the stater... nothing more. I ohmed out the pickup coil around 830ish so that seemed ok..
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Yeah pickup coil is fine, thats about where mine is.
    Tested the ignition coil? (key off ohm test as well)
    How bout the source coil? Yellow and brown on my '94.
    CDI is best and only tested with a "loaner" or new cdi. At least with such a simple electrical system there arent many things to test.
    Ignition switch
    Starter button
    Neutral Switch/ safety switches
    2 relays in the electrical box
    1 fuse
    Spark plug
    Ignition coil
    Pickup Coil
    Source Coil
    CDI
    Last 2 cost as much as the bike , seriously
    The manual lists all the wonderful and tediously boring test procedures, beware though it may get wire colors wrong. The updated wiring diagram is found only in the supplement.
    Tenaciously Deviant Unwittingly Brilliant
    Jul 2012
    Harrisburg Pa.
    17
    well, tested the CDI last night on a friend's bike, and that's good (whew).. The source and pickup coils ohm out w/in specs. I didn't get any reading on the primary on the ignition coil (but my DVM only goes to 20ohm, so maybe it isn't precise enough?) but the secondary tests correct.
    BC
    653
    I had the same problem a year or so ago. My pulse coil fried so I replaced the whole stator winding, but even after that...I would still get the same as you describe: spark when I first hit the button, and then again when I released it...but (apparently) nothing while I cranked.
    You can check it with a timing light or other means of spark detector, but I'm sure you will find that you are indeed getting a spark. I could suggest that you HOLD the wire to prove this, but that's just mean!
    Try viewing in a darkened room...My guess is that you will see that the spark is there, especially if all the coil readings are correct and your CDI is functional.
    Another thing to do is to take advantage of the "visible" spark, when you first crank it. I just "blip" my starter...touch it very briefly (a half-second or so) so that the engine turns over maybe once or twice, and 9 times out of ten she fires right up. Also, try topping up your battery with a low-current (1 amp or less) charger for at least 12 hours (overnight). Oh, and Iridium plugs rule!
    2008 TW200
    Southwest corner of BC Canada
    Nov 2011
    Alabama
    326
    That should put your problem forward of the charging system, and cdi. So relays, ignition coil, plug wire/cap, plug itself.
    Primary should be between 1.3 and 1.9 ohms, but if you dont have a sensitive enough ohm meter you dont have it.
    Double check the spark plug cap and make sure it has a good connection with the wire from the ig coil.
    I would do as BC suggested and do a lights off test just to see, also you can give the spark plug a little bend so there is less distance for the spark to jump. Just to see if its sparking. I'd throw on that new one; they're $5.
    Coils, relays, plugs.... All cheap.
    Come to think of it if you have a tw buddy throw his coil on and see if that does the trick.
    Jul 2012
    Harrisburg Pa.
    17
    will try a new coil/wire/cap next I guess then... I don't want to hassle w/ testing my coil on friend's bike just because of the hassle of getting to the coil. I did bend the electrode down a bit, w/ same results... also tossed it on the riding mower's lead, and it sparked away..
    ok, just to get this straight, the pulse coil is the separate coild assem. that provides signal to the CDI for the spark, correct? stator I get - output to power all the lights and such.. source coil is to power the CDI, then?
    Nov 2011
    Alabama
    326
    To remove the coil all you have to take off is the seat and tank. You can have it off your bike, your friends bike, tested, and back on in under an hour. I could do it in 30 as many times as I've don it. I would CERTAINLY test with your/his relays. Take off the right side cover, unclip the relay, and clip it on the other bike. 30 seconds. One relay is white, one is black. The two relays are the same size. One controls power to the starting system, and the other to the ignition system.
    Pickup coil is separate assy. It is inside the engine case and bolted next to the stator. I believe it sends the timing information. The stator on this bike isn't simply a stator though. It has the source coil made into the assy. Operose can tell you exactly what part of the coils power what, but what I do know is a bad source coil = no spark.
    Yours tested good though right? It sounds like ignition coil or relays to me. Are you testing in neutral with the clutch held in just in case of safety switch malfunction?
    Jul 2012
    Harrisburg Pa.
    17
    I know it's easy enough to get to the coil, but i hate tearing apart their bike anymore than I have to. The CDI was just a sidecover, so that was a few second exchange. Haven't thought to try the relays. thought they were ok because I was aleast getting some sparks. yes.. testing in neutral. testing w/ fully charged new battery (and a charger hooked up at same time - my charger has a 'start' function to it, so I switch it to that to make sure I'm getting plenty of current)..
  1. No Spark
    Last Post: 05-18-2013, 09:04 PM
  2. Replies: 2
    Last Post: 07-21-2012, 12:44 AM
  3. No Spark
    By stumpjumper in forum Technical Help
    Last Post: 01-07-2012, 02:38 PM
  4. No spark at the spark plub
    By acstephens in forum Technical Help
    Last Post: 05-05-2011, 10:57 PM
  5. i have no spark !
    By fleshwound135 in forum Technical Help
    Last Post: 01-13-2011, 02:48 AM
no spark
