Swing arm install
Results 1 to 7 of 7
Like Tree6Likes
  • 3 Post By TW-Brian
  • 3 Post By Peterb
Thread: Swing arm install
    Feb 2017
    Waretown NJ
    556
    Swing arm install
    OK I went to install my swing arm. Took the time to clean and grease the bushings and seals all nice. But I'm confused how to fit the inner seals. They don't fit into the swing arm for me. Or do they? And there is no room between the swing arm and engine cases.
    They came from somewhere
    87 TW
    19,036
    You could just get fancy and use sealed ball bearings. Recess them inside the swing arm a mm or so to facilitate installation, then use grease pressure through zerk fittings to press bearing back out if you like. Simple common 6901 series can be very affordable .6901-2RS-C3 - Bearing
    Under $15 should do it, no need for a $40 AllBalls kit, nor dropping ~$90 on ceramic over-kill.
    Don’t forget the grease thought as the shaft needs to stay corrosion free.
    Pleasanton, CA
    5,782
    Use the stackup of parts shown just above the axle. It is tough to get everything into place and then push the axle through if you are doing it by yourself. It helps to have an extra set of hands.
    Pleasanton, CA
    5,782
    Fred, have you or anybody else actually done this mod?
    19,036
    If I recall correctly Twilight told me he used similar bearings from AllBalls when he did his 2.5” swing arm extension. I never rode his bike afterwards though. He did not mention whether press fitting was required. to initially seat the bearings.
    The stock system may work well for robotic assembly but should I ever pull my swing arm again I shall definitely go the sealed 6901 way.
    Feb 2017
    Waretown NJ
    556
    Thanks
    Those seals in the center just seemed to have too large an OD to fit into the swing arm.
    I'll get them in there if that's where they go. They came out. I thought I was doing something wrong
    How long do TWs go before feeling swing arm play. It's nice Yammie puts grease fittings on the swing arm
    I appreciate it.
    87 TW
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,485
    "OK I went to install my swing arm. Took the time to clean and grease the bushings and seals all nice. But I'm confused how to fit the inner seals. They don't fit into the swing arm for me. Or do they? And there is no room between the swing arm and engine cases.
    They came from somewhere"
    Worst thing is when you get it all in and see a seal on the floor.
    Fred, centralwarider and admiral like this.
  1. Swing arm buffer
    By Maxpower in forum Technical Help
    Last Post: 10-15-2017, 09:29 AM
  2. Swing arm bushings
    By flyhunter3825 in forum Technical Help
    Last Post: 03-04-2016, 07:20 PM
  3. extended swing arm?
    By grewen in forum Technical Help
    Last Post: 12-19-2015, 01:24 AM
  4. Is the XT225 swing arm the same?
    By randucci in forum Performance and Customization
    Last Post: 08-04-2013, 12:21 PM
  5. Possible swing arm extension
    By adam79 in forum Performance and Customization
    Last Post: 08-23-2010, 10:12 AM
