Trail Tech Vapor speed sensor
Results 1 to 10 of 13
    Senior Member Guitarman's Avatar
    Jan 2012
    Trois-Rivieres, Canada
    167
    I just got a Trail Tech Vapor kit for TW200 but I can't figure how to install the wheel sensor. I know some of you already overcome that issue and I'd be thankful if you could share your mounting solutions with me.
    I got a disk brake system and they included that kind of sensor in the kit.
    Thank you!
    Jan 2012
    167
    Justin Yancy from Trail Tech sent me this picture!
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    That vertical mounting looks pretty straight forward. I set the same sensor horizontally but likely that was because I had some additional hardware at axle level due my Tri-Z fork set-up. Gerry
    Take care my Friend.........
    Senior Member randucci's Avatar
    Mar 2012
    Seattle, Wa.
    134
    I had the same problem, I couldn't figure out how to mount it either. It was the weekend when I did mine, so I couldn't contact them, I ended up first making a machined mounting bracket, see the first two pictures. Even though I just ride on the street, I didn't like how low it sat, so I machined a second mounting adapter and screwed it into the spedo cable mount (I'll have to add the photo tonight). I later got the same photo as above, but didn't want to leave the spedo cable attached because I wasn't using it any more. I really like the features it has, I also got the indicator light holder option.
    Senior Member kelly b's Avatar
    Mar 2011
    Indianapolis, IN
    162
    Randucci,I'd love one of those mounts! Any chance of a hook-up? If so, how much?
    Mar 2012
    Seattle, Wa.
    134
    Here is what I ended up with. I threaded the end of the aluminum adapter I made to screw onto the drive cable fitting, then, mounted the sensor into the drilled and tapped hole at the other end. Now it basically follows the old spedo drive cable route. It is actually much more stout than it might look to be.
    I made a aluminum sheet metal bracket for the Vapor that mounts to the stock spedo bracket holes. Here is a better picture of the dash turned on:
    Paradise, Calif.
    3,514
    You are something of a designer... Very nice once again... Gerry
    Mar 2012
    Seattle, Wa.
    134
    Quote Originally Posted by mrgizmow View Post
    Thanks for the award and recognition! I just like making stuff, I have spent more hours modifying my TW200 than riding it! I couldn't find a valve adjusting tool so I made my own for about $0.25. It worked great, here are a couple pictures:
    Senior Member Ice_Man's Avatar
    Sep 2013
    Western, MA
    193
    Quote Originally Posted by randucci View Post
    What are the chances of you making one of those speedometer sensor adapters for me and shipping it to 01337? I'm happy to pay via PayPal. Just not sure if I have the tools to fab it myself.
    Sent from my DROID RAZR using Tapatalk
    Junior Member Rich's Avatar
    May 2014
    1
    Is there a lot of work involved to install the vapor like you did with all the features ?How does it get the signal for rpm?
  1. Trail Tech TTO temp gauge?
    By DonBenito in forum Performance and Customization
    Last Post: 05-16-2013, 09:16 PM
  2. Trail Tech Voyager GPS review?
    By NiceAndSlow in forum Performance and Customization
    Last Post: 03-23-2013, 11:23 AM
  3. Vapor Trail Tech
    By flingwing1969 in forum Performance and Customization
    Last Post: 08-21-2012, 01:33 PM
  4. New Trail Tech Vapor install for Muley
    By JS5owner in forum Performance and Customization
    Last Post: 01-01-2012, 08:01 AM
  5. Trail Tech Vapor setup for TW200
    By twjay in forum TW200 Classifieds
    Last Post: 03-09-2011, 12:43 PM
how to minor adjustments trail tech vapor speedometer
stock spedometer
trail tech speed sensor install
trail tech speedo install
trail tech speedo sensor
trail tech vector speed sensor mounting location
trailtech vapor speed sensor
tw200 valve adjustment
vapor
vapor speed tw
vapor speedometer tw200
vapor tw200
