TW repair or mod updates
Results 1 to 7 of 7
Like Tree14Likes
  • 1 Post By Ken
  • 2 Post By Purple
  • 3 Post By scotti158
  • 2 Post By SportsterDoc
  • 2 Post By Chip
  • 3 Post By Ken
  • 1 Post By Lyterx
Thread: TW repair or mod updates
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,970
    Has there been an update on the TW which would lockup within a few miles of being driven?
    What about the new member who port and polished the heads new big piston etc? I would like to know what fixed the issue or was there a great power improvement.
    Something I noticed on mine is that when wound out at about 68mph it chugs for lack of fuel. A bigger jet didn't help performance. I think this is a fuel flow issue not a mixture issue. The Cornelius pumper carb may fix this. Is there a higher flowing petcock which might help or a bigger high flow float needle?
    littletommy likes this.
    Mar 2015
    Ynys Môn
    4,643
    No – no – yes – yes - no ....
    Ken and littletommy like this.
    - Hidden Content
    May 2013
    Groton, NY
    2,663
    If your getting 68 mph out of a TW, you are doing good.
    Ken, littletommy and Dryden-Tdub like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Jan 2017
    Southern Nevada
    1,077
    68 MPH level?
    No wind?
    Air filter clean?
    Petcock screen clean?
    Air inlet open?
    Fresh spark plug?
    Chain well lubed?
    Tire pressure?
    Guess I am better at questions than answers!
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member Chip's Avatar
    May 2017
    WI
    268
    Down hill, right.
    2017 XR650l
    2014 NC700X
    2005 ST-1300
    Wanted TW450
    Aug 2016
    Houston, Texas
    1,970
    Quote Originally Posted by SportsterDoc View Post
    68 MPH level?
    No wind?
    Air filter clean?
    Air inlet open?
    Fresh spark plug?
    Chain well lubed?
    Tire pressure?
    No noticeable wind at the time. I was sitting upright not leaned at all.
    Air filter is normal not recently cleaned.
    I don't mess with the petcock screen since I Kreem lined the tank and there is no trash unless it is from the station. I have an inline filter also.
    The air inlet is closed. I removed the baffle a while back tinkered some with the airbox but it did nothing to gain so I put the baffle back in and closed the airbox up tight.
    Old spark plug. I only change them if it is running bad or the electrode looks worn or out of spec and I don't check that much since it runs great.
    O-ring chain well lubed with sticky PJ1 Lube. I just spray more on and keep going unless I actually have dirt or mud on it.
    Tire pressure is 18 frt, 22 rear.
    I have the 49 tooth rear and the stock front sprockets.
    I did try an xt225 cheap Chinese cam which results are still up for debate. Check out cheap Chinese cam on tw200 search. I rode 2 up with my daughter this weekend and was hitting about 62mph. My wife was griping that we took off and left her, she was following in the car and I stayed in one lane without maneuvering. After I dropped my daughter off I filled up with Citgo gas and actually hit 72mph on the way home sitting straight up. This is the 2nd time to hit 72 after filling up with Citgo gas that is ethanol tainted that is all we have. I forgot that the freeway right beside me has really bad crosswinds and an uphill ramp. Where I was riding today is uphill and downhill with normal winds. I do have the Tw203 and tw204 tires which helps with top speed. I am about 210lbs so it was pulling.
    Senior Member Lyterx's Avatar
    Jun 2014
    Etters, Pa
    474
    Quote Originally Posted by Ken View Post
    Was it kind of like a hiccup, but just not all the time? Mine did that after bigger piston install. Went up a jet size and didn't help either. Ended up dropping one jet size and the seemed to help. Pull the plug and post a few pics.
    1991 TW200
  1. Updates On The Build! Pictures!!
    By haroman145 in forum General Discussion
    Last Post: 09-22-2016, 09:24 AM
  2. Updates on motorcycles, etc. etc. etc. selling bikes and stuff
    By T-Dub Ken in forum General Discussion
    Last Post: 07-14-2016, 10:42 AM
  3. Hey! Guy's in Moab! How's it going? Any updates?
    By littletommy in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-28-2015, 04:21 PM
  4. Thread Updates
    By Gerry in forum Off-Topic
    Last Post: 06-15-2012, 10:54 AM
