1987 Rectifier /Regulator
Results 1 to 10 of 12
Like Tree4Likes
Thread: 1987 Rectifier /Regulator
    Banned Vishwa Kau's Avatar
    Dec 2015
    Sri Lanka
    83
    Part Number 2JA-81960-A0 regulator/rectifier . It's perfectly fit for the 1987 TW200. Does it fit for 1998 TW200? . 1987 TW & 1998 TW 200 electrical Parts are same . Are there Any Difference?
    Mar 2015
    Ynys Môn
    4,640
    The only major difference between an ’87 and a ’98 is most of the electrical system
    Feeling lucky ?
    Ken likes this.
    - Hidden Content
    Dec 2015
    Sri Lanka
    83
    Feeling lucky ?
    Yeap ... Diffrent Wire Harnesses. But Same electricals Parts .I Mean Stator,Relays are The same .
    Mar 2015
    Ynys Môn
    4,640
    Nope - stator is different (the '87 has a different left hand crankcase cover because of this)
    The main problem is the wiring to the headlight which runs on AC - which is likely to take its power through the regulator, but not through the rectifier. I have no direct experience of the '87, but this would be the logical way to do it, or you'll risk blowing headlight bulbs
    On the '98 it's all DC, so no problem there - straight through both the regulator and rectifier unit
    But there has to be something slightly different with the '87 .......
    Ken likes this.
    - Hidden Content
    Dec 2015
    Sri Lanka
    83
    Agreed. 1987 (USA)& 1998 (Japanese Model)TW 200 Stator,Coil Pulser,CDI,Relays Are The Same. Here's The Link Check This Out .
    ?????? 1 for Yamaha TW200 1998 year | MegaZip Online Store (sales region - Japan (010), Marshal Gold (00KE; MRGD),13365146-768555) .
    Mar 2015
    Ynys Môn
    4,640
    If you look at these two pics (right click, “open in new tab”) — there seems to be subtle differences between the two years, including the part number
    You will also notice the difference between the two parts — and not only visualy, but by the fact that the ’98 has six wires coming out of it — while the ’87 has four
    And (although I can’t find the part schematic to confirm this), it is my belief that in order to fit the ’87 stator, you need the ’87 side casing — and to fit the ’98, you need the ’98 casing
    In addition to this, the ’87 CDI is well known to be very different from the ‘98
    https://www.partzilla.com/catalog/yamaha/motorcycle
    - Hidden Content
    Dec 2015
    Sri Lanka
    83
    Differences Of The Sales Region .
    Mar 2015
    Ynys Môn
    4,640
    If you try it - let us know how you get on ....
    - Hidden Content
    Dec 2015
    Sri Lanka
    83
    My Point Is About The Rectifier . According To The Japan Sales Region , Should I Use 87 rectifier without any problems on 98 wire harness .I Haven't Tried Yet. Is It Works?
    Mar 2015
    Ynys Môn
    4,640
    87 - RECTIFIER REG. ASSEMBLY (1KH- 2JA-81960-A0-00
    98 - RECTIFIER REGULATOR ASSEMBLY - 47X-81960-A3-00
    So if you look at my post #4, and the parts numbers above – probably not
    Vishwa – I don’t mean to sound rude, but I seriously think that the only way you’re going to find out is to try it and see. Anything I can come up with parts numbers you can challenge by saying “regional differences”, but at the end of the day, I don’t think anyone’s tried that combination before
    Will it work – I have no idea – I only have “suspicions” that it won’t. Having said that, it’s an easily reversible thing if it doesn’t, and I don’t think that anything is going to come to harm by trying it (apart from your wallet)
    I’ll stay out of this thread for a while – let’s see what other people have to say ……
    littletommy likes this.
    - Hidden Content
  1. 90 vs 98 rectifier/regulator
    By DrTerrible in forum Technical Help
    Last Post: 06-03-2017, 01:20 AM
  2. regulator /rectifier question
    By Camelrider in forum Technical Help
    Last Post: 12-15-2012, 08:50 AM
  3. Bad voltage regulator/rectifier?
    Last Post: 07-11-2012, 11:33 AM
  4. Rectifier/regulator
    By san_mas in forum Technical Help
    Last Post: 10-18-2011, 11:07 AM
  5. Regulator/rectifier - sound like the problem?
    By Rohnsman in forum Technical Help
    Last Post: 08-30-2010, 07:58 PM
Tags for this Thread
