Redline ? What RPM is it ?
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Member Gene-st1300's Avatar
    Aug 2011
    42
    1990 with a cleaned carb,jetted and 3 washers under the needle and it runs the same as stock. On a small digital tach it just doesn't seem to want to rev much past 7400rpm's and 50mph without the stumble,bog that feels like a rev limiter kicking in , also in nuetral it will rev out nice and smooth till it gets around 6k then start to struggle. I'm starting to think it might be a coil pack or cdi ?
    Aug 2011
    Cayce, SC
    3,109
    I believe the redline is 9500rpm.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member TWBARR's Avatar
    Jul 2011
    IN
    186
    What size jet and needle shims? Sounds like to rich a mixture.
    Aug 2011
    42
    As i stated in the original post, the bike runs with the same problem on stock 114 jetting and stock needle position as well as 3 washaers and a 120 main. Not a rich issues as it is the same trouble either way .
    Senior Member AFISHALBIZ's Avatar
    Jul 2012
    SAN FERNANDO VALLEY & CENTRAL COAST
    106
    Quote Originally Posted by Gene View Post
    I had a similar problem and it turned to be a gas venting issue. I removed the tumblers from the tank cap( 2 screws) and that seemed to fix the problem.( I also like the fact you dont need a key to fill up.) Give it a shot you can always reverse the "fix." Also for those that have a tank bag , be sure you are not smothering the cap vent with the bag. I only say , cause I have.
    Aug 2011
    42
    The cap vent was one of the first things I checked , I cleaned the tiny holes and if you turn the petcock on you get a ton of flow into a container so that is off the list, I ordered a aftermarket coil pack it try so for $20 it is a cheap test to rule the coil out .
    Redline is 10,200 according to MCN article.
    Aug 2011
    42
    Well no wonder this little bike won't go over 50mph I'm missing a couple thousand RPM's on the top end ,it won't go over 7500+or- a few hundred .
    Jul 2011
    IN
    186
    Are you running stock sprockets? 14/50
    Aug 2011
    42
    Stock gearing with stock airbox and silencer
  1. RPM redline?
    By Too Big Tim in forum Technical Help
    Last Post: 03-10-2013, 01:15 PM
  2. redline for 1000 miles
    By Turtle Chaser in forum General Discussion
    Last Post: 10-03-2010, 07:31 PM
