STUCK FORK CAPS
Results 1 to 10 of 14
Like Tree8Likes
Thread: STUCK FORK CAPS
    Senior Member AFISHALBIZ's Avatar
    Jul 2012
    SAN FERNANDO VALLEY & CENTRAL COAST
    106
    So I was off to change my fork oil...( after 7000 miles of mostly road work.) I know too long , but I am putting about 75 miles a day on the bike quite regular now...before , not so much... Anyways , I cannot get the fork caps off. I almost thought "reversed threads." , but havent seen anything about that , so... I have used a long pipe on a breaker bar with no luck...I am sure I will be able to figure this out , but I was hoping someone "here' may have a simple fix? Ive done penetrating oils and the like... I havent given up ~ just want to know if I am the only one that has run across this. Previous owner must have played in salt water? I have had a gaggle of bikes and havent run across this before,, Both caps stuck ~ yet havent had the nuts or bolts anywhere else on this bike a problem.(and Ive been places).. Thanks guys ~ Eric
    Ephrata, WA
    1,125
    Have you loosened the top pinch bolts?
    Fred likes this.
    1990 TW200
    Member Scotsman's Avatar
    Jun 2012
    Laguna Hills, California
    42
    Now might be the time to try the ATF/ACETONE penetration oil treatment----------good luck ----Scotsman
    Senior Member bikerjosh's Avatar
    Walnut Creek, CA
    1,066
    try PB Blaster (penetrating oil) several applications over a few days. it does wonders
    Not all men are capable of greatness, but all possess toughness.
    2001 TW a mod or two maybeHidden Content
    Frosty Hollow
    12,978
    I've had the opportunity to replace seals or change oil on 2 TW's. One a 91 and then a 2005. In both cases the fork caps were not seized and came off real easy, but you have to do what Rainman says, loosen the top fork pinch bolt, then try the fork cap. Otherwise it will feel like they are seized. If the fork caps are on that tight with the pinch bolts loosened, then maybe follow Scotsman and bikerjosh's advice. (Note to self: loosen, but don't remove fork caps until it's time too)
    I'll just add to what Rainman's mentioned, leave the lower pinch bolts tight to hold the fork tube until you have the fork caps loosened. Good luck.
    Jul 2012
    106
    Jul 2012
    106
    Sorry , I coped the post and pasted it again !!! thread lock !!! Looked like Loc-Tite RED ... So , a bigger breaker bar did it... Thanks again for all of your help// Eric
    Tweaker likes this.
    BC
    537
    Wow!
    Who in their right mind would use RED Loc-tite on a regularly serviced fastener? Good thing you managed to get them off without destroying them completely!
    Visit my Blog...Hidden Content or my YouTube channel: Hidden Content
    Jul 2012
    106
    Quote Originally Posted by TW_in_BC View Post
    Wow!
    Yes weird indeed ~~ and I got this bike with only 600 miles on it Well its on its way to 8000 now.. and doing great ...
    Lucky it came apart. Previous owner needs a good killing.
  1. Pic Of Your Bike Stuck
    By ronnydog in forum General Discussion
    Last Post: 12-14-2012, 10:56 AM
  2. Hard shifting/getting 'stuck' both up and down
    By skase98 in forum Technical Help
    Last Post: 10-13-2011, 08:05 AM
  3. help with fork caps
    By dganey in forum Technical Help
    Last Post: 07-17-2011, 05:54 PM
  4. Oil Drain Plug Stuck
    By hoginthebog in forum Technical Help
    Last Post: 06-27-2011, 03:57 AM
  5. Put on your Thinking Caps
    By Petrus in forum Off-Topic
    Last Post: 08-20-2010, 11:27 PM
best way to loosen a stubborn fork tube cap
cant remove fork caps
fork cap stuck
removing stuck fork tube cap
stuck fork cap
stuck fork cap haley
