Side head gasket
Results 1 to 6 of 6
Like Tree11Likes
  • 1 Post By jannaruto
  • 5 Post By elime
  • 2 Post By grewen
  • 3 Post By elime
Thread: Side head gasket
    Senior Member jannaruto's Avatar
    May 2017
    363
    Side head gasket
    Guys
    The side head gasket, the one where inside you see the gear and the timing chain on top of the head of engine
    The code is 93211-05471-00 right?
    What are the specs of this if I don't want a Yamaha official one? What I need to tell to a general bike shop and parts?
    Ken likes this.
    6,999
    Its a big o-ring. I had trouble finding one but I did find one that was a little to small. It stretched like a rubber band and fit in the groove and works like a charm.
    The groove the o-ring goes in is 4.25" in diameter. The thickness of the o-ring is about 1/8", or just a teeny bit less but I bet 1/8" will work fine.
    I use o-ring number: 2-155 N-70 It is a little small and has to be stretched on but it works just fine. It was the biggest one the place I went to had so I was stuck but it was cheap and I got it right then and there -- no waiting.
    Try Graingers.
    littletommy, admiral, Ken and 2 others like this.
    May 2017
    363
    Try Graingers.
    Brother any possible info in millimiters?
    I guess rubber is 108mm diameter and 3mm thickness?
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,411
    take the cover to the store with you
    littletommy and elime like this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    May 2017
    363
    Quote Originally Posted by grewen View Post
    Not so easy when most of your friends and dad are working... XD that's why I usually go by myself since I work in different hours of the day
    6,999
    Quote Originally Posted by jannaruto View Post
    When you take the cover off you can measure the diameter.
    The thickness of the o-ring is just about 3mm. When you put the new o-ring in the groove you want it sticking up a little bit so when you tighten the bolts the rubber is compressed. Once you have a compressed o-ring and metal to metal contact, cover on the head, just a teeny tiny bit tight is all you need. DON'T over tighten the bolts or you will strip the threads in the head. It doesn't have to be very tight and it will stay in place.
    Peterb, Dryden-Tdub and ejfranz like this.
  1. I was SURE I blew my head gasket...
    By Ricklesss in forum Technical Help
    Last Post: 06-02-2016, 02:17 PM
  2. head gasket leaking oil = need help
    By Jassenk in forum Technical Help
    Last Post: 05-26-2015, 09:20 AM
  3. Missing head gasket?
    By PalmStateCrawler in forum Off-Topic
    Last Post: 09-18-2012, 11:51 PM
  4. That !$%/* head gasket leak keeps worsening!
    By Guitarman in forum Technical Help
    Last Post: 06-06-2012, 08:20 PM
  5. Head gasket leaking oil?
    By Udoug in forum Technical Help
    Last Post: 10-25-2011, 02:01 AM
