New o-ring chain is on
Results 1 to 6 of 6
    Stanwood,Wa
    1,898
    Got the new o-ring chain on today. Should I clean off all the factory lube or leave it and just clean and relube when needed next time? I have my chain wax that I've been using on the bikes forever with good results.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Mar 2011
    Gobles, michigan
    1,824
    I think you can just use the factory lube until you need to clean it and then re-lube...... Have you learned the stick under the rear foot peg trick for keeping the tire off the ground while cleaning and lubing??? If you haven't then E-mail me back and I'll go out and measure the OAL and send it to you.. Make sure your lube is rated for O-ring chains.. OMM.
    Stanwood,Wa
    1,898
    Quote Originally Posted by omm View Post
    Yes have the stick for that. Made one years ago when it was first mentioned on the site. Great idea that keeps on giving. Thanks for the quick reply. Matter of fact, I had to use it on the road yesterday when my old stock chain came off.
    Gen:27:3
    -Ronald Reagan
    Aug 2011
    Cayce, SC
    3,109
    I just use a scissor jack from one of my old cars under the peg. Is the stick like the crutch leg gizmow uses. How do you get it up on there by yourself.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Stanwood,Wa
    1,898
    Same concept as Mrgizmo and Liz.
    this is Liz's. Mine is just a dowel about the size of a broom handel. I think it is an old rake handle that was broke . I just cut off what I needed. I can through it in my box and have it with me always. Good thig to because it would not been fun getting the chain back on not being able to lift the rear end.
    Gen:27:3
    -Ronald Reagan
    Uh, did you run the original chain until it stretched so much it fell off, then wrap a new chain around the original sprockets?
  1. what do you use on your O ring chain
    By aladdin in forum General Discussion
    Last Post: 05-30-2012, 03:48 PM
  2. O-ring chain?
    By mykdee in forum General Discussion
    Last Post: 12-19-2011, 03:11 PM
  3. New O-Ring Chain: Q's
    By bend42 in forum Technical Help
    Last Post: 11-02-2011, 10:14 PM
  4. o-ring chain
    By mrx916123 in forum General Discussion
    Last Post: 07-04-2011, 09:19 PM
  5. Standard vs. O ring vs. X Ring Chain
    By Fishman393 in forum General Discussion
    Last Post: 05-14-2011, 05:46 PM
do i leave the coating on new o-ring chain lube
