Oil Leak
Results 1 to 6 of 6
Thread: Oil Leak
    Member Senior Dirt Dog's Avatar
    Jul 2012
    33
    I just bought my first TW, a used 2007 TW200 5,100 miles. I have discovered a small oil leak that appears to be coming from right above the starter cover. Has anyone experienced this problem, and what is the solution?
    2010 base gasket.
    Tennessee
    1,285
    2010 base gasket.
    To expand, just a bit, there was a problem with the cylinder base gasket for a couple years there, yours included. Get a 2010 or newer gasket to replace it. It's not terribly hard if you take your time, cross your t's, dot your i's, etc. There is a tutorial here on the forum for replacing just this thing. Good luck to you and congrats on buying a wonderful bike.
    Jul 2012
    33
    Quote Originally Posted by assquatch20 View Post
    Jul 2012
    33
    Please post the link to the tutorial. Thanks for your input.
    Ephrata, WA
    1,125
    1990 TW200
  1. Oil Leak
    By ldw72120 in forum Technical Help
    Last Post: 02-25-2013, 08:49 PM
  2. oil leak from where
    By jerz006 in forum Technical Help
    Last Post: 07-07-2012, 06:00 PM
  3. Oil leak...
    By xdac in forum Technical Help
    Last Post: 10-27-2011, 12:32 PM
  4. Oil Leak
    By B-dub in forum Technical Help
    Last Post: 08-09-2011, 01:19 AM
  5. Oil Leak
    By Mike Mecredy in forum Technical Help
    Last Post: 07-19-2011, 06:15 PM
how to stop oil leak yamaha tw200
tw 200 cylinder base oil leak 2001
tw200 leak
tw200 motorcycle cylinder leak
tw200 oil leak
yamaha tw200 oil leak
