Base Gasket leak???
Results 1 to 7 of 7
Like Tree22Likes
  • 2 Post By gutrons
  • 5 Post By TopPredator
  • 5 Post By scotti158
  • 2 Post By gutrons
  • 3 Post By elime
  • 1 Post By gutrons
  • 4 Post By gutrons
Thread: Base Gasket leak???
    Junior Member gutrons's Avatar
    Oct 2015
    Western Colorado
    15
    Base Gasket leak??? SOLVED!!! SEE BELOW
    Hey all,
    Hoping someone has an answer... Just brought this baby home, checked oil etc. and took it out for a quick ride. Replaced the headlight today and was heading out for some miles... during pre-flight noticed oil seeping at the bottom of the head!! I remember reading somewhere about an updated base gasket but can't locate the post...Checked the bolts and they are tight (didn't check torque, just that they aren't falling out) but I won't be ablr to dig in to her until tomorrow, figured I'd start here. (This is my '89 with 734 miles on it BTW) Thanks in advance!!
    Also...noticed this at the same time, pretty sure that tapered spacer was flush on both sides when I brought it home (and I know it is on my '87). Wondering if the leak is related? Bike runs perfect, just don't want to burn up a motor if I've got an issue. Also just confirming that is the timing chain tensioner? Thanks all, I'm still learning!!!
    Last edited by gutrons; 10-29-2017 at 12:36 AM. Reason: ISSUE RESOLVED W MEMBER SUGGESTIONS
    Runners:
    87 TW200
    99 TTR90
    01 XR100
    Paperweights:
    79 GT80 (2 stroke)
    84 GL1100 Goldwing Aspencade
    "Expect problems and eat them for breakfast" - Alfred A Montapert
    Jun 2014
    Bel Air Maryland
    4,170
    littletommy, Ken, Lyterx and 2 others like this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    May 2013
    Groton, NY
    2,663
    The "tapered spacer" is the cover for the manual cam chain tensioner. It looks like it's cross threaded or broke. Could be getting some oil from that.
    littletommy, Ken, Moabman and 2 others like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Oct 2015
    Western Colorado
    15
    That's what I was afraid of
    Guess with that much time parked the gasket dried up? Total bummer, was hoping for a cream puff! Oh well! Another winter project I guess.
    Awesome write up!!! Thank you!!
    Runners:
    87 TW200
    99 TTR90
    01 XR100
    Paperweights:
    79 GT80 (2 stroke)
    6,999
    First replace that cover that is on kind of cock-eyed. Use a new o-ring. Then decide if the base gasket is leaking. I bet it isn't.
    When you tighten it, tighten it just enough to flatten the o-ring and no tighter. It will break if you do make it to tight.
    Mel, littletommy and maddawgj like this.
    Oct 2015
    Western Colorado
    15
    Aha. I found a pic in the manual that shows it better, I thought it was a separate piece, not connected to the nut on the end. Ill see tomorrow why it's askew. Thanks!
    littletommy likes this.
    Runners:
    87 TW200
    99 TTR90
    01 XR100
    Paperweights:
    79 GT80 (2 stroke)
    Oct 2015
    Western Colorado
    15
    Thanks elime! Thinking about it there is some oil towards the backof the head, could have originated at the tensioner cap and after the bike was parked migrated up to the front of the head mimicking a base gasket leak. All fingers crossed!! Ill let you know what I find. Thanks again guys.
    Update!!!
    The cam tensioner cap was indeed cross threaded and totally mangled, guessing it took a hit when the old owner loaded it up and I hadn't noticed it before. Took the cap off and replaced it with the one off the '87 and a new o-ring, cleaned every last drip of oil off the base and lower bolts, couple hail mary's and headed out. 25 min later (lower RPM's, just putputting around town) came back and found the base pristine and free from any oil residue. Great catch elime! Saved me a whole bunch of stressing and laying awake tonight! Chances ar I'd make the correlation after looking a little closer (and laying awake all night) but always nice to get a leg up from the millions of hours of experience we can tap into right here. BEST FORUM EVER!
    More ridiculous questions coming you way very soon!
    Thanks again everybody.
    BF
    Runners:
    87 TW200
    99 TTR90
    01 XR100
    Paperweights:
    79 GT80 (2 stroke)
  1. Cylinder Base Gasket Leak
    By supertrooper in forum Technical Help
    Last Post: 10-29-2017, 02:42 AM
  2. Base Gasket Leak
    By Swamp in forum Technical Help
    Last Post: 09-05-2013, 10:56 PM
  3. Base Gasket Leak
    By bogey72 in forum General Discussion
    Last Post: 08-26-2012, 11:54 PM
  4. 07 base gasket leak
    By small's in forum Technical Help
    Last Post: 03-25-2012, 10:41 AM
  5. Base Gasket Leak Question
    By lonedave in forum Technical Help
    Last Post: 04-26-2011, 03:49 PM
news
