High speed puff of smoke from exhaust
Results 1 to 10 of 14
Like Tree32Likes
Thread: High speed puff of smoke from exhaust
    Senior Member jannaruto's Avatar
    May 2017
    363
    Hey guys,
    I was yesterday going around with some of my TW friends
    Basically all the TWs when max throttle at high speed they produce a lil bit of clear smoke, a very small small small puff, I guess is kinda normal
    But one of the bikes produced a grey puff of smoke, sometime even one after another, like 2-3 puffs of smoke in 4-5 seconds
    The smoke puff is kinda "big" like the size of a tire diameter, greysh coloured, and only when you use throttle a lot or when at high speed you open it completely
    What can cause this?
    Maybe idle mix screw?
    Ken and littletommy like this.
    Mar 2015
    Ynys Môn
    4,631
    Did he wash the bike recently ?
    - Hidden Content
    May 2017
    363
    Not that I know, but let's say he did? But as said I am quite sure last time he washed was like 1 month ago or more
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,958
    The rings may be starting to get a bit worn. Black smoke is usually the carb misadjusted. I usually will just keep a good eye on the oil level and (if it's not real cold) add Lucas heavy duty oil stabilizer or use 20/50 weight on the next oil change. The Lucas may tighten clutches up which can adjust out. If you ride cold freezing weather I wouldn't do anything other than watch that oil level.
    littletommy likes this.
    May 2013
    Groton, NY
    2,663
    I think the TW was sending some smoke signals saying "HELP ME".
    Ken, grewen, ejfranz and 2 others like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    May 2017
    363
    Quote Originally Posted by Ken View Post
    So I should make the mix a bit leaner maybe? Like 1/4 or 2/4 of a turn in?
    Mar 2015
    Ynys Môn
    4,631
    Likely over-filled with oil - but you may want to check his air filter first, in case it's got either wet, or excess oil / fuel in there
    Always look for the simplest fix first ......
    elime, littletommy, Ken and 1 others like this.
    - Hidden Content
    May 2017
    363
    What do you mean with overfilled with oil? Like instead of putting 1 liter he put 1,2 liters?
    Air filter is clean
    Mar 2015
    Ynys Môn
    4,631
    Pretty much, yeah - easy to do if both wheels are not level
    On the air filter, take a look at the tube underneath the air filter box - if there's anything in that tube, that may be the problem
    Ken, elime and littletommy like this.
    - Hidden Content
    6,999
    Sounds like oil smoke, maybe rings, maybe valve stem seals, maybe both. If it only happens after extended high speed / wide open throttle runs I wouldn't worry about it. When / if it reaches a point where it is smoking all the time, or nearly all the time then fix it.
    You can play with the carburetor if you want to but I really doubt it will make a difference. If the bike is running well I would leave the carburetor alone as chances are it will run worse after "adjusting the carb." and it will still smoke.
    grewen, Ken, littletommy and 1 others like this.
  1. High Speed Jet #110
    Last Post: 11-04-2016, 07:04 PM
  2. High speed lag, not getting to top speed
    By jgaff in forum Technical Help
    Last Post: 05-11-2016, 11:03 PM
  3. High speed lane splitting...
    By littletommy in forum Off-Topic
    Last Post: 01-21-2015, 12:40 AM
  4. Cutting out at high speed - 08 TW
    By invisicamo1 in forum Technical Help
    Last Post: 02-27-2013, 09:07 PM
  5. Carb/ high speed problems
    By reillyyz125 in forum Technical Help
    Last Post: 04-23-2012, 12:56 AM
