Front sprocket size and chain length
Results 1 to 10 of 13
Like Tree48Likes
Thread: Front sprocket size and chain length
    Junior Member mtnmanidaho's Avatar
    Oct 2017
    Boise, ID
    23
    I have a 72 tooth sprocket coming to me from Sprocket Specialists but they were all out of the 14 tooth front. This has me thinking that maybe I should consider a 13 or 15 tooth instead and wanted to field some opinions. I'm wanting to build a climber, I wont be going more then 25 mph so top speed isnt an issue.
    Secondly could someone recommend a chain link size for me, i see alot of TW sites selling 130 link kits but dont want it to be too short for such a large rear sprocket.
    jtomelliott49 likes this.
    Frosty Hollow
    13,166
    Yes, a 13 or 15 front sprockets will work. I've been using a 13T front sprocket with the various rear sprockets throughout the year (50, 55, 60). I've ordered my 13T front sprocket either from eBay or Amazon I can't remember which, listed for a TW.
    It came with a spring clip
    instead of the bolt retainer you see on the stock 14T sprocket.
    You can get a 14T from Rocky Mtn ATV/Motorcycle for $10.74 (3 in stock). If you order it today you'll probably get it tomorrow. 99% of the parts I order from them I get the next day unless I order on a Friday or Saturday.
    https://www.rockymountainatvmc.com/oem-schematic/4
    The closest I could get to how long of a chain was using this calculator which only went as high as 13/65 = 152 links. I suspect you'll need more so you'll probably have to buy two chains and cut & splice to get the links you'll want.
    Sprocket Calculator - the easy motorcycle sprocket and chain calculator
    I've heard of at least 2 forum members who've used a 70 or 72T rear sprocket but I can't find any info using the forum or google search functions.
    Mar 2015
    Ynys Môn
    4,636
    Bodi is the one you need to talk to
    https://tw200forum.com/forum/trails-o...like-goat.html
    - Hidden Content
    Senior Member Pete H's Avatar
    Dec 2016
    Upstate NY
    107
    72 tooth? A 50 comes stock. You must get extra traction turning left with that sprocket. A 14 front and 50 rear comes stock and I think that is way too low for my 260lbs. I switched out for a 15t and 47t option on mine. With a 72 tooth rear you must top out at about 40 mph. Yea!, I would say to go to a 13t front if you want to be in 3rd before you get to 10mph. and if you truly have a 72T rear you will need at least 142 links.
    Apr 2014
    993
    I've run as high as 15-44 and as low as 14-65. As he states; he doesn't plan on doing more than 25 mph. You wouldn't be able to go where he is going; and he won't be able to keep up with you where you ride. But you each will have a great time on such a diversely set up machine. Ain't it wonderful!
    Jun 2017
    Milwaukee, WI
    1,295
    Quote Originally Posted by old w/?? View Post
    Yeah - it’s amazing what these little monsters can do. You can have a tractor that will climb the side of your house one day, and a street ripper the next day with a couple of sprockets and and a handful of tools. The only thing you can’t do is run 75 on the interstate. At least not for long.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Senior Member Stufidmotard's Avatar
    Jun 2017
    Greenleaf, Idaho
    126
    Mine will to out around 35mph with the 13/63 and it will climb just about anything I'm willing to aim it at. so a 14/72 should be in the same ballpark
    littletommy and jtomelliott49 like this.
    Dec 2016
    Upstate NY
    107
    Wow, I didn't know you could get a rear sprocket that big! The thing must be a tank. I can see the appeal for the woods. You could easily get off and walk along in the super nasty stuff.
    Pleasanton, CA
    5,782
    Just so you will know what that 72 tooth rear sprocket will look like on your TW, here are a couple of pics of JMPNFSH's bike when we fitted his chain at a Wrench & Ride a couple of years ago. He was planning on riding the Rubicon Trail with this setup. I don't remember what size his smaller sprocket was, but you can see the section of chain that was added for the larger sprocket.
    littletommy, admiral, Ken and 4 others like this.
    Dec 2016
    Upstate NY
    107
    Wow, I am impressed. I am a bit confused by the duel sprocket set up. I believe I see 3 master links. You can actually take out enough extra links to run either sprocket during a ride? That is pretty hard core.
    littletommy, Ken and jtomelliott49 like this.
  1. Replies: 5
    Last Post: 01-01-2016, 01:15 PM
  2. quick sprocket chain length question
    By Dark Sol in forum Other Bikes
    Last Post: 12-31-2015, 01:35 AM
  3. Sprocket/chain length calculator
    By goldenhtr in forum Technical Write-Ups
    Last Post: 04-20-2014, 10:47 AM
  4. Front Sprocket - keeper Bolt different size
    By ezman671 in forum Technical Help
    Last Post: 10-03-2011, 01:54 PM
  5. good replacement chain for use with stock sprocket size
    By grt1982 in forum Technical Help
    Last Post: 07-11-2011, 06:07 PM
