Cleaned carb, now bike won't idle
Results 1 to 10 of 15
Like Tree36Likes
Thread: Cleaned carb, now bike won't idle
    Member HobbitRider's Avatar
    Jun 2016
    Central Texas
    38
    So I am no mechanic, but pulled my carb for the first time and cleaned it. I replaced all the parts I could with the All Balls carb rebuild kit, cleaned the rest. The bike had sat for awhile and would not run well at low RPM - lost of surging. But now it is hard to start and will not idle at all. cranked for a long time with and without choke, but finally had to crack the throttle for it to start. It runs smooth enough with throttle, but dies instantly when I let off it.
    What did I do wrong?
    littletommy likes this.
    2015 Triumph Tiger 800 XRx
    2009 Kawasaki KLR650
    2001 Yamaha TW200
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    980
    Not sure what you did wrong, but check the threads below
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Vacationing in the Bahama's
    17,567
    You probably would have been better off using OEM parts.
    Ken likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Jun 2016
    Central Texas
    38
    Which threads?
    2001 Yamaha TW200
    17,567
    Scroll down to the bottom of the page and look for Similar Threads.
    Ken likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Jun 2017
    Milwaukee, WI
    1,292
    Have you tried adjusting the idle setting? Might make it more rideable until you can get to the cause of the problem.
    Ken and maddawgj like this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Jun 2016
    Central Texas
    38
    I have turned the throttle stop screw in and out, but it haven't found any setting that will keep the bike idling.
    Badgerflorida likes this.
    2001 Yamaha TW200
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,954
    Try putting your stock pilot valve back in. I tried an aftermarket one and it never started good. I slapped the old one back in and it starts perfectly. As LT said oem is the only way to go on these carbs.
    Badgerflorida, maddawgj and Fred like this.
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    1,954
    I meant pilot jet
    Jul 2012
    Wet-ern Washington
    1,415
    Quote Originally Posted by HobbitRider View Post
    What year is it? That will let us know which style, old slide, or new CV, the carb is.
    What carb kit did you buy? Was it the right kit for your model year? Did the new jets match?
    Did you get the new pilot circuit screw get the a new o-ring properly installed? Did the old one come out properly first? Sometimes they get stuck up there.
    If it was a 2001+, did you get the little silver bushing looking thing that goes under the main jet holder put back in? This has been lost by many during a carb cleaning, and being without it can cause the symptoms you describe. See this thread for a breakdown of the CV carb and its parts... https://tw200forum.com/forum/technica...ification.html
    - Leisure Time Larry -
  1. won't rev off idle. Carburetor? any other possibilities?
    By overlanddreamer in forum Technical Help
    Last Post: 04-09-2016, 08:33 AM
  2. Replies: 11
    Last Post: 05-05-2015, 07:30 AM
  3. Replies: 28
    Last Post: 08-30-2011, 04:26 PM
  4. 87 TW200 won't idle
    By heimy in forum Technical Help
    Last Post: 10-23-2010, 06:43 PM
  5. Cleaned Carb, now I have a question
    By Quicksand in forum Technical Help
    Last Post: 08-16-2010, 07:15 AM
had my carb cleaned and it wont idle
yamaha tw 200 wont idle
