Forks - the Universe - and keeping it simple ......
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Like Tree115Likes
Thread: Forks - the Universe - and keeping it simple ......
    Mar 2015
    Ynys Môn
    4,631
    I’ve been doing some reading regarding “fork improvements” — there are many threads, and much good information — but I’ve got to say, the more I read, the more my head spins ….
    “Fork emulators” — “Rider sag” — “Longer springs” — “Spacers” — “The broom stick method” (whatever that means) — the list of possibilities is endless
    Given that my ’98 is fortunate enough to have a set of “proper forks”, (eg the ones with drain holes at the bottom), it occurs to me that changing the oil should be a relatively simple affair, involving none of the above “complications” — get the old stuff out, and re-fill with the desired amount
    Sounds simple enough ….
    I know that following the manual on this is futile — and would ask the others on here on what personal experiences with viscosity and volume they have had (200lb rider — wet)
    Remember, this is the bike that goes into reverse when the perceived threat of a socket is presented, so for the bikes sake (and mine) — I just want to “KISS” this
    How much — and what weight ?
    (And if I could keep the “clack”, it would be appreciated) ……….
    - Hidden Content
    19,023
    Clack seems to disappear and rebound dampening appears if oil level is raised higher than ~130mm as measured from top of vertical, compressed, empty fork tube. I use 10w oil after first flushing out old aluma-sludge with cheap automatic transmission fluid ( ATF). A few more ml of oil will firm things up nicely for a 200 lb wet rider. I set mine at ~128mm but living in desert climates I am rarely wet.
    Mar 2015
    Ynys Môn
    4,631
    Now there you go again - with the “top vertical compressed” bit - and the “130mm”
    All I need to know, is how much to pour into the top, and what viscosity
    Assume I don’t have any spare broomsticks (just for a moment) —nor a laser range finder to poke down the top to find the 130mm sweet spot
    Not even an oil finding Hamster to report back to me (complete with little LED headlight) attached to a piece of string
    No gimmicks, no gadgets, no rodents — just me, an empty fork, a bottle of oil, (and a worried looking bike)
    And regarding the original Yamaha OEM “clack” — as long as it’s barely noticeable, I’m sure that’ll be fine. Although I have always regarded the “clack” as an indicator that the forks where working to within Yamaha specifications, my dentist disagrees. He seems to think it’s my teeth- the Doc says it’s likely to be my nuts — and frankly, it’s confusing, and costing me a fortune
    And what’s with this “rebound” bit — the TW forks rebound? — Why wasn’t I told of this ?
    I thought that was a myth ……
    - Hidden Content
    Dec 2015
    San Diego
    1,865
    Purple you desire a simple cc or oz measurement to accomplish what is variable goals. But that being said it would be great to have a table of oz’s or cc’s of fork oil to say be at 130 mm from the top for xxx-xxx lbs of rider. 128 mm, 125 mm etc. I don’t know if the capacity of the forks changed when they removed the plug and if this would work for all years.
    Ok who is manic enough and has drain holes in their forks to add and measure different levels to come up with this table? Any takers?
    If you have the bucks the best option seems like procycles kit of progressive springs and emulator with recommended oil based on your rider weight.
    There is an easy way to measure the depth of the oil just use a pencil mark a line on it near the top stick it into the hole of the fork up to the line and then measure the from wet spot to the line bingo your fork oil depth. Just make sure what ever you put into the forks to measure with is longer than the length you want to measure. Lol. Of course you have to remove the cap and springs and then compress the fork tubes. Supporting the front of the bike while removing the springs, etc. it is not as complicated as it sounds.
    Mar 2015
    Ynys Môn
    4,631
    So – in summary – we have absolutely no idea on how much oil should go into a TW fork leg, other than to employ the “diving Hamster on a bit of string” method
    This pretty much confirms my own reading of the situation – but surely we have had to address this before ……
    - Hidden Content
    19,023
    This is not the first time someone has shouted down the well seeking a simple volumetric response to no avail. Sorry Purple, I knew your goal but was too embarrassed to admit to my not measuring by volume last time I forked up my TW. I lack a proper graduated cylinder but suppose I could always weigh before and after and then convert to milliliters next time. What is the specific gravity of Bel-Ray 10W fork oil anyways?
    Skiing the slopes in Switzerland
    17,585
    Pour a 8 ounce bottle of fork oil in each fork, test, drain excess from plugs if needed. ??
    Tweaker, buellzebub and gandolf like this.
    1st John 1:9
    John 3:16
    John 3:17
    May 2013
    Groton, NY
    2,663
    The service manual says 8.05 US ounces (or 238 ml) per fork.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Hailey, ID
    3,404
    Sorry Purple, it just doesn't work that way. If I told you to pour exactly 385 milliliters of 10 Wt. Fork oil into each fork to arrive at a measurement of 130 mm, I would be wrong. Since you have to remove the fork caps and drain to add new oil, you have already done 3/4 of the job. All you have to do now is take the spacer and springs out, close the drain bolt, add several ounces of ATF and exercise the forks a few dozen times. Lather, rinse, repeat. This step is important to get rid of the sludge at the bottom of the forks. It helps to drain into a glass container so you can see the ATF clear up after a couple of repetitions.
    Then compress the forks all the way, add about 8 oz. of fresh 10 wt. fork oil and using a 1/8 inch wood dowel available at most model stores or even hardware stores, make a mark from one end at 130 mm and put that mark at the top of the fork tube. Add oil until the bottom of the dowel gets wet, just a few cc at a time. Yes, this does take time but if you want to do it right you can't skip this step. The forks are quite sensitive to small increments of oil, and the level is the way to measure accurately.
    For your weight, the 130 mm level is very close to perfect. When it's there, put the springs and spacers back in, EXTEND the forks all the way and put the caps back on. It's worth doing right. I did this 11,000 miles ago and the forks have worked just fine ever since. It's now about time to change out the oil again, and I will use the exact same procedure again.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Member TW196's Avatar
    Mar 2017
    Baltimore, Maryland
    48
    I always wanted a no brainer oil volume to just dump into my forks. One day I was watching a video, from a Pennsylvania guy that goes by "Smightification" on YouTube, showing the installation of Procycle higher rate fork springs that called for 8oz. of oil per the installation instructions. And later reading through many fork oil threads I saw that lizardbreath suggested the use of ATF fluid as an acceptable alternative to 10w fork oil. So when I flushed mine that's what I used. 8oz. of mercon/dextron tranny fluid in each tube has worked fantastically for me on road and off. 10w fork oil of any brand would be fine but the viscosity of the mercon/dextron is excellent and it's cheap. I weigh 200lbs. for reference.
  1. Batteries - life, the Universe, and everything ......
    By Purple in forum General Discussion
    Last Post: 08-26-2017, 09:48 AM
  2. Fibromyalgia and Keeping My TW 200
    By RikR in forum General Discussion
    Last Post: 06-02-2017, 06:48 PM
  3. keeping the TW but thinking of another bike,,,but which one?
    By rastaman in forum General Discussion
    Last Post: 05-25-2017, 03:18 PM
  4. keeping your TW clean ?
    By mtn_goat in forum General Discussion
    Last Post: 03-18-2015, 06:16 PM
  5. Replies: 5
    Last Post: 05-03-2012, 12:23 PM
