Stripped fork drain bolt????
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Like Tree157Likes
Thread: Stripped fork drain bolt????
    Senior Member rivershot's Avatar
    Sep 2014
    Middle GA.
    262
    So with all the talk about "Fork Oil" I decided to change mine while doing a front tire swap. The plug in the bottom of the fork on the brake side came right out, the other side broke loose and just spins, and it will NOT tighten back up!!!
    Did I f-up or am I just F-ed????? And yes I was turning the right way, "unless one is backwards thread"
    I have enough going on in this little shop as is.
    admiral and maddawgj like this.
    2001 TW200
    1999 DR350SE
    2002 Sportster 1200
    Suzuki Ozark 250 (Broke)
    Rokon RT140 (in a basket)
    Belarus AS250 tractor
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,485
    An impact with a good quality allen head socket works great but only if you have experience with an impact gun.
    Mar 2015
    Ynys Môn
    4,631
    I have a Hamster you can borrow if that will help .......
    - Hidden Content
    Mar 2015
    Ynys Môn
    4,631
    There are two types of screws at the end of the forks, depending on the vintage - the one that holds the damper rod in position, that is vertical to the bottom of the fork - and the one on the side of the fork, which is a proper drain plug
    All have the vertical - but not all have the one on the side
    Depends very much on the one were talking about ........
    - Hidden Content
    Pleasanton, CA
    5,781
    admiral, Purple, rivershot and 7 others like this.
    Mar 2015
    Ynys Môn
    4,631
    If he’s got one of the later models, he should be able to retract the screw by Admirals method to stop the damper rod from spinning, and use a magnetic driver bit at the screw – the thread is in the damper
    You can use something like a nail to line the holes back up when it comes to re-fitting
    - Hidden Content
    Sep 2014
    Middle GA.
    262
    Well it's a 2001, only bolt, nut (me) is the Allen head pointing straight up. I was hoping , like you, to get this done easily. Oh well. I do have a good 3/8 impacts, both air and cordless. I guess it can't hurt toooo try! If that doesn't work I can finish the disassembly of the one that came out and make a tool to get the other one apart.
    Thanks all for the heads up of what I now have done and, have to do.
    Next question, what oil??? LoL
    Any guesses of which tire was on it? Which tire is going on it?
    Again, Thanks!
    2001 TW200
    1999 DR350SE
    2002 Sportster 1200
    Mar 2015
    Ynys Môn
    4,631
    Thanks Brian - great pic .....
    - Hidden Content
    Mar 2015
    Ynys Môn
    4,631
    You just need to stop the insert from turning and you'll be fine ....
    littletommy, maddawgj and Ken like this.
    - Hidden Content
    Sep 2014
    Middle GA.
    262
    Well I put 1 too many pics in so it should be easy.
    littletommy and maddawgj like this.
    2001 TW200
    1999 DR350SE
    2002 Sportster 1200
  1. Stripped float bowl drain screw
    By rav819 in forum Technical Help
    Last Post: 04-14-2016, 06:53 PM
  2. Carburator drain screw stripped
    By Matojo in forum Technical Help
    Last Post: 10-20-2015, 03:51 PM
  3. stripped drain plug help
    By mrx916123 in forum Technical Help
    Last Post: 05-06-2015, 08:31 AM
  4. stripped the drain screw on my TK carb!
    Last Post: 01-03-2013, 11:59 AM
  5. stripped out bowl drain screw
    By phazer in forum General Discussion
    Last Post: 09-05-2011, 10:11 PM
