Brass Pilot Plug
Results 1 to 6 of 6
    Junior Member ikwestbrook@yahoo.com's Avatar
    Aug 2012
    Hello all,
    I am a new TW owner and new to the forum. This is probably a simple question, but how do I remove the brass plug covering the pilot screw? I don't have a lot of carburetor experience and I don't want to damage anything.
    My situation:
    I am trying to fix a problem where my TW starves for fuel if I open up the throttle too far. I suspect it is the float level. I have adjusted it several times without fixing the problem. After my last adjustment, the bike is now difficult to start and keep running. I think I have lowered the float level too far and intend to raise it a hair today. I am hoping to get it running well enough to go for a 300 mile ride this weekend. If I can't get it this time I am preparing myself to remove the float and carb float needle valve.
    All input is appreciated!
    Thanks!
    Senior Member Ayers Garage's Avatar
    Jun 2012
    125
    Screw a screw into it a little ways and pull it out by gripping the screw with wire cutters and levering on it.
    Pleasanton, CA
    5,682
    Welcome Montana!
    There is a small hole in the center of the plug. Take a sharp pointed screw like a wood deck screw and thread it into this holes until it gets a good bite. Then just pull/wiggle the screw and the plug should come right out. Just discard the plug so you will have easy access to this jet for future adjustments.
    Brian
    Senior Member rm_hm's Avatar
    1,619
    BV did a nice write up some time ago with pictures.
    http://tw200forum.co...0/ShowPost.aspx
    http://tw200forum.co...uel-screw-plug/
    Aug 2012
    Thanks everyone!
    Senior Member Omega Man's Avatar
    Jan 2012
    Taxachusetts
    173
    I did mine on the bike. The space is tight so I bought a Milwaukee right angle drill adapter-
    And used a Tec (self-drilling) screw right into the chuck. This made the distance from the tip of the screw to the back of the chuck just right to fit in. It drilled a little and as the threads on the screw hit- the plug came out. Sweet! HTH, OM
    "It's more fun going fast on a slow bike than going slow on a fast bike" UK
    1994 TW200, 2009 F800GS loaded,
  1. pilot jet
    By greendub in forum Technical Help
    Last Post: 08-27-2013, 07:16 PM
  2. Replies: 2
    Last Post: 07-21-2012, 12:44 AM
  3. pilot/air screw
    By PalmStateCrawler in forum Technical Help
    Last Post: 06-04-2012, 08:27 AM
  4. Pilot Jet
    By Joe in forum Technical Help
    Last Post: 01-11-2012, 07:34 PM
  5. Pilot Jet adjustment
    By bruisr in forum Technical Help
    Last Post: 09-12-2010, 07:21 PM
brass 1-8 deck screw plug
tw200 pilot plug
