Removing the rear tire
Results 1 to 9 of 9
    Senior Member mga60tw's Avatar
    Fl
    215
    I am getting ready to remove the rear tire to replace the sprocket and chain. What do you use to jack up the bike so you can get the tire off the ground?
    Ephrata, WA
    1,125
    I used this for a couple years...
    ...until my birthday last year. I love this jack. Well worth the money.
    1990 TW200
    Senior Member ATXthumper's Avatar
    Aug 2010
    Austin, TX
    231
    milk crate shimmed with 2x4s
    edit: not a smart way to do it...its quite unstable..
    '01 TW200: Tusk D-Flex Handguards w/ Spoilers, Pro Taper Grips, LEDs in Idiot Lights, Headlight Rockguard, Stearns Seat Pad, Oversized Footpegs and a Loud Ass Horn -SOLD
    '91 TW200: Bone Stock
    Junior Member mrutkaus's Avatar
    27
    a regular floor jack up under the (new more rugged) skid plate with the kickstand down will raise the rear tire up yet still keep the bike fairly stable, I've found.
    Mike
    Member TWmonster's Avatar
    Sep 2010
    Spokane WA
    51
    I use my Monsterbrace inspired from MrGizmo's crutch stand. It works great and can be taken with you!
    My TW is HUNGRY!
    '01 TW200, WPS Handguards, D2moto Foot Pegs, Jimbo's Cafe Fairing, Tusk Handle Bar Risers, Yamaha Rear Rack, 47 Tooth Rear, 3/16 Fuel Filter, Monsterbolts, Monsterbrace, HJC CL-14 Fuse, HJC ACX1, Cortech GX-AIR, RU Outside Teton Gloves
    BC
    623
    I used to place two jackstands (one on either side) and use a long crowbar. Pass the bar underneath the swingarm junction and place the far end into the first jackstand...then holding the bike steady, I would lift up on the bar and then place the close-end into the other jackstand. It doesn't have to be very high...just an inch or so off the ground. The advantage is that the bike seems a bit more stable than being on a crutch-stand. That way if you need to wrestle with the axle or adjuster cams, you don't have to worry about the bike tipping sideways!
    I also use a variation of the crutch-stand idea...works easier on other tasks like chain adjustment!
    2008 TW200
    Southwest corner of BC Canada
    1996 TW200 Edmonton, AB
    590
    I put a 2X6 or two under the kick stand and then lift the bike up against that until I can get enough blocks underneath the skid plate. Helps if the front tire is against the curb to stop it rolling. It's such a light machine compared to my old bikes I really enjoy that such a thing is possible!
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    i just set a jack-stand with a rag on it on one the right side, then tilt the bike over onto it, and slide a jack-stand under the left side of the swing-arm.
    i used a milk crate a few times, but found the jack-stands to be easier and more stable.
    Member shadow's Avatar
    Sep 2010
    Boise, Idaho
    92
    I guess I am one of the silly few who actually bought a bike stand. Align it up under the swing arm, and cam it up. Solid, works great.
  1. Kenda rear tire?
    By Rohnsman in forum General Discussion
    Last Post: 04-02-2013, 01:45 PM
  2. rear tire
    By 671tdub in forum Performance and Customization
    Last Post: 03-05-2013, 05:43 AM
  3. new rear tire
    By duckmutts in forum General Discussion
    Last Post: 02-28-2012, 02:02 PM
  4. Pirelli MT 43 for a rear tire?
    By tfactor in forum Technical Help
    Last Post: 01-05-2012, 02:57 PM
  5. Removing front tire w/ disk brakes???
    By PalmStateCrawler in forum Technical Help
    Last Post: 10-18-2011, 06:10 PM
how to remove rear tire tw200
