Need Help Removing Timing Chain Sprocket From Crankshaft
Results 1 to 10 of 17
Like Tree53Likes
Thread: Need Help Removing Timing Chain Sprocket From Crankshaft
    6,999
    I have an XT225 crankshaft I picked up for a song but it needs a new connecting rod. I found a new connecting rod on Aliexpress and a place in Arizona that will do the work but they want the crankshaft completely stripped before proceeding. A quick trip to Harbor Freight for a gear puller, I installed the gear puller and tightened the removing / center bolt to the point I can't make it any tighter plus I fear damaging the sprocket, and the dang thing hasn't shown a hint of movement. I tried tapping on it with a hammer and applying heat with a propane torch and no luck.
    I am open to suggestions.
    Senior Member buellzebub's Avatar
    Oct 2015
    Breedon on the Hill, UK
    343
    Hi elime,
    With the puller fully tightened try giving the centre (sorry, center lol) bolt a few smart taps with a hammer. With luck the tension and the shock should move it
    Edit: Sorry, just re-read it and realised you've tried tapping it. Doh!
    Frosty Hollow
    13,169
    Sgt. Schultz here. I know nothing...that can help.
    Skiing the slopes in Switzerland
    17,585
    Bigger hammer, hit it harder, Penetrating oil and more heat?
    elime, Badgerflorida and maddawgj like this.
    1st John 1:9
    John 3:16
    John 3:17
    6,999
    I will try penetrating oil. Remember, I don't want to wreck anything.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    machine shop?
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Senior Member Heli-Mech's Avatar
    Jan 2014
    Dartmouth, Nova Scotia
    379
    I used that exact style of puller to remove my timing gear ....... twice ........ since I got the orientation wrong on install the first time around. I didn't use the crank bolt, instead I used the flat snap head and a sacrificial piece of 3/16" thick aluminum between the crank nose and flat snap head. I wouldn't want to apply force to the crank bolt threads the way you have it currently set up.
    It takes a lot of force and will "SNAP" and "PING" as its being removed. It will work you'll just have to come on to it. I used my big impact gun and heated it with a MAP torch. Put the crank in a vice pinching on the the webs only ...... then set your self up heat the fuck out of it and give it hell.
    For install I put the crank in the freezer overnight and then heated the bering and gear up and they dropped right on into postion. I use a small old toaster oven and aluminum baking pan ... submerged the gear and bearing in ATF fluid and heated to 250-300 for 10-15min or so.
    Pay close attention to the "DOT" on the gear face, It aligns dead center with the keyway in the crank ..... and if you use my above tricks you have seconds to align it before it cools tight.
    6,999
    The bolt is bottomed out but still I wondered how wise it was to apply force to it. I will remove it and start over. Thanks for sharing your experience.
    Jan 2014
    379
    No worries man. Good luck and play safe!
    littletommy and Badgerflorida like this.
    Jan 2014
    379
    I also pulled it via the toothed gear not the upper lip that your puller is set up on .... which seemed sketchy at the time but worked fine.
    Also when you tighten the clamp halves for the puller just snug them up. If you over tighten them it applies additional clamping friction to the press fit piece.
  1. Replies: 5
    Last Post: 10-27-2016, 12:20 AM
  2. Timing Chain broke!
    By OSOK in forum Technical Help
    Last Post: 11-18-2013, 05:05 PM
  3. The right tool for removing timing plugs
    By rurlndum in forum Technical Help
    Last Post: 09-07-2013, 02:38 PM
  4. Cam chain/timing chain adjustment?
    By GaryL in forum Technical Help
    Last Post: 08-31-2013, 08:18 PM
  5. timing chain
    By maupin81 in forum Technical Help
    Last Post: 06-19-2011, 06:04 PM
news
