Carb leak after repairs
Results 1 to 3 of 3
    Member Olydog's Avatar
    Oct 2011
    Spokane, Wa
    56
    After cleaning the jets and replacing the leaking bowl gasket in my carb it now leaks out of the tube on the bottom left in the picture. Not the drain tube with the screw. Any ideas what I did wrong?
    Jun 2012
    Southern Michigan
    269
    If I am not mistaken and get your description that is the overflow drain. That means either your float is stuck, adjusted wrong, or your needle valve is stuck or leaking.
    Oct 2011
    Spokane, Wa
    56
    ok thanks I am gonna open it up and check it out.
  1. Carb leak at mixture screw
    By sjctool in forum Technical Help
    Last Post: 04-21-2013, 04:47 PM
  2. Oil Leak
    By ldw72120 in forum Technical Help
    Last Post: 02-25-2013, 08:49 PM
  3. Oil Leak
    By Senior Dirt Dog in forum Technical Help
    Last Post: 08-03-2012, 09:48 PM
  4. Oil leak...
    By xdac in forum Technical Help
    Last Post: 10-27-2011, 12:32 PM
  5. Carb Leak with Picture
    By Snake2715 in forum Technical Help
    Last Post: 05-25-2011, 06:29 AM
