Routine maintenance
Results 1 to 5 of 5
    Member slinky's Avatar
    Apr 2012
    Sydney
    77
    Hey gang I found this comprehensive guide someone has taken the effort of putting on the net. Seems very helpful from first glance and thought it might come in handy for some of us down the line.
    http://tw200.wiki-site.com/index.php...ne_Maintenance
    Tennessee
    1,286
    Quote Originally Posted by slinky View Post
    http://tw200.wiki-si...ine_Maintenance
    That's actually one of our members that got that started. We really should contribute to it more, but it's definitely handy.
    Desert, SoCal
    7,369
    I believe Mr. Gizmow deserves credit for resurrecting, compiling and maintaining the Wiki info, a task he does quietly with far too little fanfare.
    Kudos, Gerry.
    Senior Member losttourist's Avatar
    Jun 2012
    Ontario Canada
    171
    That's how I learned to do my oil change on my bike.
    The Southwest
    566
    It's good write-up.
  1. Jetting for maintenance
    By Adam-n-nevada in forum Technical Help
    Last Post: 11-02-2012, 07:53 PM
  2. Torque Values and Maintenance Manuals
    By JRD in forum Technical Help
    Last Post: 09-18-2012, 09:04 PM
  3. Dipping a toe into motorcycle maintenance
    By DonBenito in forum Technical Help
    Last Post: 08-11-2012, 11:50 PM
  4. Maintenance on a 2006 with 1000km
    By steve_tb in forum Technical Help
    Last Post: 08-06-2011, 10:53 PM
  5. fork oil and general maintenance
    Last Post: 05-04-2011, 12:02 PM
