520 Sprocket and chain
Results 1 to 10 of 14
    Senior Member msmiller's Avatar
    Aug 2011
    184
    Any issue with changing to a 520 size chain and sprockets they seem to be more available?
    Desert, SoCal
    7,369
    Somewhat overkill and will slow you down but not hard to do.
    Aug 2011
    184
    Thanks for the info, I might have to go with 520. Not having any luck finding the 428/14 steel in stock. So the 520 is stronger? Could this cause damage to the engine? Will keep searching. M
    Desert, SoCal
    7,369
    News to me. Never had any problem finding as many as I want. Anyone else experiencing a sprocket shortage?
    520 is heavier and gobbles a bit more power.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    My dealer did not have the sprockets in stock and it seemed to take him forever to try and get what I wanted in. I had him cancel the order and I simply ordered online and got what I needed in 3 days. Gerry
    Take care my Friend.........
    Germany, Werdau
    1,014
    I use since 3 or 4 years a 520 chain kit on 2 TW (11/49 for my offroad TW, 13/40 for my street TW).
    I haven't noticed problems.
    I just had to modify a small white plastic part when I use the 13 front sprocket, which is under the generator cover.
    It's the part with the number 2
    Aug 2011
    184
    I am finding the 428s online but have not found one place that has them both in steel. Would like o get the sprockets and a new Oring chain for the same place at the same time. Any suggestion?
    Aug 2011
    184
    Quote Originally Posted by mrgizmow View Post
    Have not tried my dealer. I figured they would just search online like I am. Did your place have both front and rear in steel?
    Aug 2011
    184
    Quote Originally Posted by macbig2k1 View Post
    Thanks good to hear I can switch if needed. Do you like the 13/40 set up?
    Ephrata, WA
    1,125
    Quote Originally Posted by msmiller View Post
    Oemcycle
    Lytle Racing
    1990 TW200
  1. Sprocket and O Ring Chain Help...Please!!
    By RIF in forum Technical Help
    Last Post: 07-16-2013, 04:32 AM
  2. Replies: 0
  3. New sprocket old chain?
    By Lido in forum Technical Help
    Last Post: 09-29-2011, 04:11 PM
  4. Chain and Sprocket
    By mga60tw in forum Technical Help
    Last Post: 09-04-2010, 12:13 AM
  5. Chain and sprocket replacement
    By Rohnsman in forum Technical Help
    Last Post: 09-01-2010, 06:46 AM
520 sprocket upgrade for tw200
520 sprokt par numbers
convert tw200 520 chain
tw200 520
