Removing Monoshock spring?
Results 1 to 4 of 4
    Member retro's Avatar
    82
    I want to take the spring off my shock for re-painting. Is there anyway that I can do that?
    Thanx Much!
    Retro
    Senior Member JarrodWeaver's Avatar
    Austin, Texas
    112
    You can easily remove the spring on the TW shock. First, place the shock top-side-down on a floor jack; second use a tiedown strap and tightly secure the bottom of the spring (now at the top because its upside down) on both sides to the bottom of your jack; third, here is the dangerous part - hold the shock very securely straight up and have someone slowly jack up the shock; fourth, the spring retainer will come loose when the spring is tensioned - remove the retainer; fifth, release the tension on the spring from the jack. That's all it takes.
    Senior Member catamount's Avatar
    Aug 2010
    Vermont, USA
    323
    Quote Originally Posted by Jarrod Weaver View Post
    This technique will work but be advised that it can be very dangerous if your strap gives way, or slides off, etc.
    Most automotive stores will "rent" you a spring compressor for free (you give them a deposit). Your use a ratchet to compress the spring and it holds it there for you, safely.
    Check out my custom TW200 build Hidden Content .
    TTR225 SS header, FMF Turbine Core 2 pipe, EK o-ring chain, 15T front sprocket, 50T rear sprocket, 20W fork oil, Drag Specialities speedometer, Victory Vegas headlight, Acerbis universal supermoto front fender, Vintage Yamaha chrome gas cap, Integrated LED rear tail/turn/brake light, Yamaha Blaster shock, Pro Taper SE ATV High handlebar, Western Powersports off-road handguards, Pro Taper Pillow Top Lite grips, Over-sized foot pegs, Maxxis 6006 front tire, seat cover from eBay seller mac32756.
    Senior Member ATXthumper's Avatar
    Aug 2010
    Austin, TX
    231
    +1 on the spring compressor much safer and easier too.
    '01 TW200: Tusk D-Flex Handguards w/ Spoilers, Pro Taper Grips, LEDs in Idiot Lights, Headlight Rockguard, Stearns Seat Pad, Oversized Footpegs and a Loud Ass Horn -SOLD
    '91 TW200: Bone Stock
  1. Removing the spring from the shock
    By nfpgasmask in forum General Discussion
    Last Post: 07-23-2013, 02:00 AM
  2. Removing rust?
    By drs6222 in forum General Discussion
    Last Post: 09-09-2012, 10:14 PM
  3. Removing sidestand spring
    By TWisty in forum Technical Help
    Last Post: 02-17-2012, 12:23 PM
  4. removing the carb
    By zoolander in forum Technical Help
    Last Post: 02-07-2012, 06:53 PM
  5. Removing the rear tire
    By mga60tw in forum Technical Help
    Last Post: 09-22-2010, 05:39 AM
how to change mono shock cable
how to change spring on mono shock
how to change the spring on a monoshock
how to remove monoshock retainer
jack monoshock
mono shock removal
monoshock spring compression floor jack
monoshock upside down tool
remove mono shock spring
spring compressors
tw200 how to remove rear spring
tw200 how to replace spring
