Cam Chain Replacement Question
Results 1 to 10 of 17
Like Tree13Likes
Thread: Cam Chain Replacement Question
    Senior Member jannaruto's Avatar
    May 2017
    363
    Hey guys,
    Having replaced my cam chain I have a very stupid question about
    The manual says put the crankshaft at TDC on the COMPRESSION STROKE aligning the T mark with the arrow and the top sprocket line with the relative arrow
    What they exactly mean with compression stroke? I dismounted the whole head to replace a gasket and so the piston moved a bit up and down when trying to remove the stator
    With COMPRESSION STROKE they mean basically when the piston goes UP right?
    Because:
    Piston goes down = fuel and air enter
    Piston goes up = compression
    Piston goes down = because of explosion
    Piston goes up again
    But when you dismount everything you "loose" track of the compression stroke right?
    Or I should dismount again the top sprocket and make another full turn of the stator in example?
    Hope my question is clear
    Frosty Hollow
    13,169
    If you align the mark on the cam sprocket and the mark on the top of the cam sprocket opening your piston, valves, and crankshaft will be in the correct engine timing. You can use this same system when you adjust your valves during routine maintenance.
    If the marks do not line up, then you have to move the cam chain forward or rearward until the marks line up. I think forum member elime has a similar picture.
    littletommy likes this.
    May 2017
    363
    That's what I did, align the T with the arrow mark and the line on the top sprocket with the arrow mark
    Everything was aligned together, that's what I did
    My question came from the specification of COMPRESSION stroke, I guess with head dismounted and re-mounted, cam chain removed etc etc there is no more compression or exhaust stroke, you need first to re-attach the timing chain correctly and then the valves will start to move again creating the compression and exhaust stroke right?
    So I could remove technically the cam chain, spin the stator for like 10 minutes with my hand, re-align all the marks (T with arros and line with arrow) and everything will still be 100% synched right?
    Frosty Hollow
    13,169
    My question came from the specification of COMPRESSION stroke, I guess with head dismounted and re-mounted, cam chain removed etc etc there is no more compression or exhaust stroke, you need first to re-attach the timing chain correctly and then the valves will start to move again creating the compression and exhaust stroke right? Yes
    So I could remove technically the cam chain, spin the stator for like 10 minutes with my hand, re-align all the marks (T with arros and line with arrow) and everything will still be 100% synched right? YesThe only purpose of the cam chain is to move/operate the valves. With the cam chain removed, the rest of the engine will move but not the valves (crankshaft, piston). When the marks are lined up the piston will be at Top Dead Center (TDC) on the compression stroke and the engine will be in the correct timing.
    Dec 2015
    San Diego
    1,865
    In order to spin the motor with the chain off I think you may need to remove the spark plug because the valves will remain in what ever position they were in before undoing it and if they are closed it will be full compression. Also a 4 cycle engine has two top dead center positions. To be on the compression cycle both valves need to be closed. If you rotate the piston around to the top and one of the valves are open you are not on the compression cycle.
    May 2017
    363
    Quote Originally Posted by Tweaker View Post
    True but as said the cam chain was not connected since was in the replacement process, once you align the top sprocket with the line and arrow they will be automatically on close position, then you align the stator with T mark, and put on the cam chain, so you will have both lines aligned with both arrows
    I guess this is correct
    admiral and littletommy like this.
    Frosty Hollow
    13,169
    When the cam sprocket is installed, (the cam sprocket only goes on one way) it is synchronized with your crankshaft already. Unless the cam chain stretches or skips a sprocket tooth, or the entire engine was taken apart and put back improperly your cam sprocket and crankshaft T Mark should be in synchronized alignment. When you align the cam marks with each other you don't need to worry about the T Mark on the Flywheel/Stator. Then all you have to worry about is lining up the cam alignment marks.
    May 2017
    363
    Well when I changed mine like 1 month ago I dismounted the head to change gasket and removed both stator and logically the top sprocket
    So I just tought to ask again XD
    I will check anyway again the alignment maybe these days because I opened another kinda interesting topic about performance loss...
    Maybe you can help?
    Frosty Hollow
    13,169
    I want to add this to my post but the forum or my computer isn't letting me edit a post.
    When you have the cam marks aligned it wouldn't hurt to look and verify you're flywheel/Stator timing mark is in the correct position.
    littletommy and Tweaker like this.
    6,999
    I tried to add my pictures but it wouldn't let me.
  1. Replies: 3
    Last Post: 07-28-2016, 01:35 AM
  2. 2007 cam chain adj. question
    By Rider21 in forum General Discussion
    Last Post: 10-04-2015, 02:38 PM
  3. Seal replacement during chain/sprocket replacement
    By TWROG in forum Technical Help
    Last Post: 02-03-2015, 12:42 PM
  4. Cam chain/timing chain adjustment?
    By GaryL in forum Technical Help
    Last Post: 08-31-2013, 08:18 PM
  5. need to check cam chain on an 05 @3k mi?
    By n.e.illinois in forum Technical Help
    Last Post: 04-27-2011, 09:09 PM
