91 carb/petcock
Results 1 to 10 of 13
Thread: 91 carb/petcock
    Senior Member FnMag's Avatar
    493
    Leaking fuel from one of the orifices below carb even when petcock is in off position. Should just need to replace seals, yes ?
    If so, drain tank first before replacing seals?
    Or is it stuck float?
    Thanks.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    Likely more than one problem.
    If fuel is continually flowing out the overflow drain, even with the petcock off:
    a: petcock is leaking (see this post by Broken Veteran}:
    https://tw200forum.com/forums/85249/ShowPost.aspx
    b: float valve needle is not closing (because of wear, crud build up, or float is bad or maladjusted.
    c: o-ring on the float valve seat is old, dried out, or worn, and fuel is leaking around it.
    jb
    Senior Member AFISHALBIZ's Avatar
    Jul 2012
    SAN FERNANDO VALLEY & CENTRAL COAST
    106
    Quote Originally Posted by Mike View Post
    Thanks.
    Pull off your fuel line going to the carb. with the petcock off. If gas flows , PETCOCK problem.. Id buy a new one for $19 unless you can find a gasket kit MUCH cheaper.. If thats not the problem , snap your throttle from wide to off a few times ,,, sometimes that'll seat things.. You could "tap" the carb. bowl a bit with a non mettalic tapper... Screwdriver handle works..If you are still leaking , pull the bowl and replace the float bowl seat.. You could try to clean it a bit before you spend the $4...
    493
    I'll check with the fuel line first since I've just bought replacement line and have been meaning to do it for a week now. I'll also drop the bowl and clean. Currently have 3/4 tank left that has seafoam in it.
    I'll go ahead and order a new float valve seat and needle too. Maybe u can get it here before my next day off.
    Thanks guys!
    493
    Can't figure out which part is float needle on rockymtnatv site.
    Help!!
    Senior Member Ayers Garage's Avatar
    Jun 2012
    125
    Needle valve set comes as a kit with the needle, seat, and o-ring under part number 2JX-14107-00-00. You're looking at part number 17 on the carburetor microfiche. It also shows in stock too. Price is 16.87.
    493
    Thanks. Have it, new float bowl gasket, float pin and petcock on the way.
    Jun 2011
    Dothan, AL
    1,715
    If you need help Mike let me know.
    2005 TW200 (SOLD)
    2013 DR650
    493
    Will do n202, I have a doctors appt thurs at 1 so I'm going to try that morning if I can get motivated. If not, I'm off Sunday if you want to come by or I can ride up there. We REALLY need to go exploring together and talk TDubs. Do you still have my #??
    Mike
    Jun 2011
    Dothan, AL
    1,715
    Pm it to me just in case I don't. I can meet you Sunday.
    2005 TW200 (SOLD)
    2013 DR650
  1. Petcock repair
    By Tirebiter in forum Technical Help
    Last Post: 04-15-2013, 07:23 PM
  2. Will xt225 gas cap and petcock fit TW200?
    By scott in forum Technical Help
    Last Post: 09-21-2012, 10:25 PM
  3. Leaky carb / leaky petcock
    By Under Dog in forum Technical Help
    Last Post: 10-10-2011, 05:45 PM
  4. Gas Petcock
    By RockyTFS in forum Technical Help
    Last Post: 05-26-2011, 07:18 PM
  5. Pingel petcock
    By mtjoe in forum Technical Help
    Last Post: 03-13-2011, 07:00 PM
tw200 91 model problems
tw200 bad pet cock
