Help quick air filter question
Results 1 to 10 of 12
    Member mtngirl's Avatar
    Hailey, Idaho
    44
    Hi, just changed oil my first time, replaced battery and cleaned air filter but I have this stuff ( No-Toil Rim Grease) that I believe you are supposed to put around base of air filter (a bead for sealing) but not sure fully where it goes and my guy friend you usually helps me is out of town. Any quick advice?
    Thanks Mtn Girl
    Senior Member rm_hm's Avatar
    1,619
    Looks like it's made for a much different different style of foam filter then a stock tw. I would think that goo would clog up the mesh screen in the airbox.
    Edit: From what I've been able to google. it's used mainly on off road bike and atv multistage foam filters to keep it from wiggling off the airboxes solid base.
    The TW airbox cover makes a decent seal without any sealant, I've seen them go underwater without leaking. If any air managed to leak under the cover it would still have to go through the foam filter.
    [media]http://www.youtube.com/watch?v=sm6AmQPpYEo[/media]
    If you have a stock tw air filter.
    Remove it
    Degrease, clean and dry
    Re-oil (with whatever brand you like) ,wring out excess oil and reinstall.
    I extended my airbox drain hose to hold extra oil, if I over oil my filter again.
    Hailey, Idaho
    44
    I know, our air filters are different than everybody else's! Well maybe I will blow it off, but want to protect the filter as much as possible as I live in a really dusty climate.
    Frosty Hollow
    13,079
    Honestly, I'm not sure how or where to apply it on our TW filters!
    Ephrata, WA
    1,125
    Just put it around the seal of the plastic piece that covers it. You know, the piece you screw on to the bike.
    1990 TW200
    Hailey, Idaho
    44
    Thanks guys, Rainman that is just what I figured out, used a q tip!
    thanks, mission accomplished
    Aug 2011
    Cayce, SC
    3,109
    You do not use that on our type of air filters. That is used on cone shaped filters to seal it to the plastic, keeping "dirty" air from seeping under/around the filter and dirtying up the carb and engine.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Hailey, Idaho
    44
    ok thanks, just used a smidge so hopefully ok
    Aug 2011
    Cayce, SC
    3,109
    You will be fine but I would avoid using it in the future. Keep it simple and good job working on your bike. Now if I could only get my fiancee to do some of this on her bike. It's hard enough to even get her to watch!
    Senior Member gfletcb's Avatar
    Jun 2011
    181
    Ya, its for where a filter might butt up to a flat, it should bo ok for what you did, i think the more important thing is to oil the foam for the dust to stick to
  1. Need some help quick! Oring question?
    By bogey72 in forum Technical Help
    Last Post: 05-20-2013, 07:42 AM
  2. Quick Help
    By BC4Lyphe in forum Technical Help
    Last Post: 03-28-2013, 11:23 AM
  3. first oil change, quick question
    By russ5415 in forum Technical Help
    Last Post: 02-13-2013, 10:25 PM
  4. Quick base gasket question
    By Larry in forum Technical Help
    Last Post: 07-22-2012, 09:11 PM
  5. OIL FILTER QUESTION
    By harleyjoe43 in forum Technical Help
    Last Post: 02-03-2012, 06:19 PM
