Clutch fixed, now Kickstart problems!
Results 1 to 10 of 14
    Member SCARE!'s Avatar
    Feb 2012
    New Zealand
    46
    I installed (well nearly) my new clutch on the weekend..
    One of the Clutch Spring Bolt/Screw broke off! Few words were spoken..
    So I have a couple spares on their way.
    My question is how tight do these have to be done up?
    They obviously compress the spring more, giving a tighter clutch..
    The harder the better for me, I just don't want to break another..
    And I don't have a torque wrench..
    Any help would be great!
    6,960
    Were you using the manual and a torque wrench?
    Feb 2012
    New Zealand
    46
    Quote Originally Posted by Tony View Post
    stupid question really.. do i really need to answer?
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Quote Originally Posted by SCARE! View Post
    No, you don't need to answer. Tony apparently overlooked that you didn't have a torque wrench. I think we all make our fair share of mistakes. Personally, I try to be patient with others' mistakes in hopes they will be patient with mine. The book calls for 6 Nm or 4.2 ft. lb of torque on the bolts, which of course doesn't really help you out since you don't have a torque wrench. So as I see it, you have two options, either ask around and try to locate a torque wrench, or just tighten them up with a little less force than you used when you twisted them off. Free, downloadable manual here if you're interested. Clutch assembly and torque values begin on Page 135.
    Feb 2012
    New Zealand
    46
    Thank you kind sir.
    I have the manual thanks. I will definitely buy a torque wrench and save the hassle guessing (and breaking)!
    May 2012
    Tucson, AZ
    976
    My local autozone let me borrow a very nice torque wrench for free.
    I left them with a $100 deposit, and they refunded it to me in full a few hours later when I was done with it.
    Autozone is right around the corner from me, so buying a torque wrench of my own got bumped way on down my to-do list when I realized I could borrow one for free any time I want.
    I think Pep boys has the same sort of deal going, others may as well.
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    6,960
    If you are near a Harbor Freight they have inch pound torque wrenches for $10 when on sale. If not I can send you one in tomorrow's mail.
    Feb 2012
    New Zealand
    46
    I think the postage to New Zealand may be a bit much haha!
    Thanks for the thought!
    I am buying a cool little Powerbuilt 1/2"Dr Digital Torque Adapter for a good price locally
    6,960
    You're in New Zealand! Dang! I missed that too. I am not having a good day.
    For peace of mind put a little blue Locktite on the bolt. I think you are going to be surprised how "not tight" 4.2 foot pounds are. The side cover bolts have a torque spec and should they should all be the same tightness. Good luck.
    An aside: When I go to look at a used motorcycle for sale I always ask if the seller does his own maintenance. If he says yes I then ask what brand of torque wrench he uses. If he doesn't have one it tells me a lot. Point being there is a right way and a wrong way. Congrats on getting a torque wrench. Using it is well worth the effort.
    Feb 2012
    New Zealand
    46
    ok so the Digital Torque thing I was about to buy only goes down as low as 40nm.
    the clutch springs need to be done to 4nm - is this just finger tight or what?
    are there torque wrenches that go as low as 4nm, or am I wasting my time?
  1. Bending an aluminum kickstart... ?????
    By zardoz in forum Performance and Customization
    Last Post: 10-04-2012, 09:10 AM
  2. kickstart and oil cooler installed
    By 6Z37RLC in forum Performance and Customization
    Last Post: 08-18-2012, 01:31 PM
  3. Broken kickstart retention clip wall
    By sakogu in forum Technical Help
    Last Post: 07-21-2012, 05:34 AM
  4. 87 is all fixed up- im a happy camper
    Last Post: 02-22-2012, 04:47 PM
  5. Miss, Backfire, Hesitation ***Fixed!***
    By pantera1 in forum Technical Help
    Last Post: 06-16-2011, 04:50 AM
