Neutral Light ?
Results 1 to 8 of 8
Like Tree35Likes
  • 3 Post By excalibur
  • 5 Post By littletommy
  • 8 Post By elime
  • 5 Post By maddawgj
  • 3 Post By Fred
  • 5 Post By elime
  • 3 Post By grewen
  • 3 Post By socalnative
Thread: Neutral Light ?
    Senior Member excalibur's Avatar
    Nov 2017
    La Center, WA
    118
    Neutral Light ?
    A little help with where to start looking for the culprit.... I have no owners manual nor service manual at this point.... The neutral light has not worked since buying my TW 2010 less than a month ago with only has 345 miles at time of purchase.
    Thanks for any help.
    Gene
    2010 TW 200 Dual Sport
    2017 Harley Softail Slim w/110 Cubic Inch Screamin' Eagle engine
    2005 Yamaha 450 Kodiak 4x4 Quad
    Biking through Africa with Cornelis
    17,595
    Gene, go to the Technical section of the forum, click on Sub Forum and you will find the owner and shop manual.
    Quote Originally Posted by excalibur View Post
    Gene
    1st John 1:9
    John 3:16
    John 3:17
    7,001
    Change the bulb first. Hopefully that is the problem.
    Pete H, Ken, Badgerflorida and 5 others like this.
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    +1 I’d bet that’s it and the best place to start.
    Ken, Pete H, Badgerflorida and 2 others like this.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    19,069
    I would check the bulb before replacing it, i.e. measure it's impedance, inspect and clean the bulb's terminals as well as the bulb's socket for dirt and/or corrosion. With bulb removed measure for voltage showing up at the bulb's socket terminals.
    7,001
    Swap the bulb with the bulb in the socket next to it and see if it works.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,413
    I would replace them with leds while you have it apart
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Nov 2016
    So. California, inland empire
    309
    The neutral safety switch is under the output/front sprocket cover. If you have to remove it I'd buy a cover gasket before starting that job.
  1. My first problem-neutral light
    By Michael Bryce Winnick in forum Technical Help
    Last Post: 03-23-2016, 05:52 PM
  2. Neutral light not coming on all the time.
    By old mad max in forum Technical Help
    Last Post: 08-10-2014, 10:45 PM
  3. Neutral or 1st at red light ?
    By willinbc in forum General Discussion
    Last Post: 08-10-2012, 08:37 AM
  4. Neutral Light and shifting / engine questions
    By TWBUSHMAN in forum Technical Help
    Last Post: 07-10-2012, 07:39 AM
  5. Wanted - Speedometer and neutral light cover
    By cohassetsteve in forum TW200 Classifieds
    Last Post: 04-25-2011, 09:22 PM
neutral light tw200
