Compression Test
Results 1 to 10 of 12
    Senior Member Henrici's Avatar
    Sep 2010
    Big Island, HI
    180
    Hello what number should I be looking for if I compression test my TW?
    Ephrata, WA
    1,125
    1990 TW200
    Sep 2010
    Big Island, HI
    180
    Thanks for the information. I bought a compressions tester and it only is reading 60psi. This is the first and only time I've used it. I ride my bike everyday and haven't noticed a drop in performance. If the compression is that low (half the recommended minimum) would I notice a difference or is the gauge more likely incorrect? Thanks for any help!!
    Member sakogu's Avatar
    Penticton, BC, CANADA
    64
    just checking you had the starter cranking for several seconds with a nice full battery? most wont get full psi on first or second cycle
    64
    cut out, sorry double posted...
    Devon, England.
    614
    Quote Originally Posted by Henrici View Post
    I hope I'm not teaching Granny to suck eggs here, but to get a correct reading the engine should be warm and the throttle wide open. If you have a CV carb you will have to remove it as the slide only opens when there is a vacuum in the manifold.
    I hope that helps you.
    Sep 2010
    Big Island, HI
    180
    I did it with the engine cold and hot, full and closed throttle and got the same 60psi reading. My TW is a 2007 not sure if it has a CV carb or frankly what that is. Thanks.
    Sep 2010
    Big Island, HI
    180
    Oh maybe I should add that I bought the compression gauge for a truck but thought I'd test it on the TW because I thought at least it was is good running condition....
    Devon, England.
    614
    2007 has a CV (constant velocity) carb. This type of carb relies on a vacuum on the intake side of things to lift the throttle slide so when the engine is not running i.e when doing a compression test the slide does not open.
    But as you say the bike runs fine then maybe your tester is not working properly.
    Sep 2010
    Big Island, HI
    180
    Quote Originally Posted by uktw125 View Post
    So would I need to detach my carb. to get an accurate reading?
  1. What should engine compression be at?
    By Beewerks in forum Technical Help
    Last Post: 07-15-2017, 10:40 AM
  2. Compression check
    Last Post: 04-29-2013, 06:13 PM
  3. Engine loses compression when warm
    By Uwdlk2no2 in forum Technical Help
    Last Post: 04-22-2013, 07:20 PM
  4. Finding the Compression Ratio
    By ronnydog in forum Technical Help
    Last Post: 12-09-2012, 04:21 PM
2000 tamaha tw200 compression
compression for a tw 200
compression test for yamaha tw200
how much compression dose a yamaha tw200 have
how to do a compression test tw200
tw200 compression
tw200 compression test
tw200 compression test tw200forum
tw200 resonable compresion
tw200 yamaha compression
what size compression tester adapter for yamaha tw200
yamaha tw200 compression
