'91 Electrical Q
Results 1 to 5 of 5
    Member canadainshiver's Avatar
    Oct 2011
    New Brunswick, Canada
    77
    1991 tw200. When key is turned to 'on' should any lights or instrument clusters work? Or does bike need to be running?
    1991 TW200 Hidden Content
    Ephrata, WA
    1,125
    When key is on, headlight, front running lights (turn signals), rear tail light, speedometer bulb, and instrument cluster lights (if engaged) should come on.
    1990 TW200
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by Rainman View Post
    Also your neutral light, if you are in neutral.
    Junior Member FredTW200's Avatar
    Jul 2012
    Florida
    7
    Can I ask about the rear turn signals / running lights?
    With the switch in the on position both before I start the motor and also when the motor is running; the rear running lights/turn signals are not on.
    I think they used to be. All the other running lights are on.
    And when I use the turn signals they do not work at all on the front or back; it is like I am not using the turn signal switch at all.
    This just started and now I cannot remember if the rear running lights would include all three lights on the rear ; tail light, left trun signal, and right turn signal.
    Thanks,
    Fred
    Desert, SoCal
    7,369
    Running lights are only in the front.
    Tail light should be on.
  1. Am I asking to much from the TW's electrical system
    By hooker in forum Technical Help
    Last Post: 10-28-2012, 06:35 PM
  2. Electrical Question/problem
    By kgriff in forum Technical Help
    Last Post: 09-06-2012, 04:50 PM
  3. Yet another weird electrical problem
    By TWisty in forum Technical Help
    Last Post: 06-24-2012, 01:49 PM
  4. electrical failure??
    By yamamont in forum Technical Help
    Last Post: 11-24-2011, 07:15 AM
  5. Electrical mystery for '87
    By lagarto in forum Technical Help
    Last Post: 02-18-2011, 07:28 PM
