12V at coil?
Results 1 to 3 of 3
Thread: 12V at coil?
    Member ldw72120's Avatar
    Oct 2011
    Central Arkansas
    69
    My TW has no spark. I replaced the coil, still no spark. Is the ignition wire going into the coil supposed to be 12V?
    Senior Member rm_hm's Avatar
    1,619
    What year is it?
    Ye olde manual for my late model calls for checking the following for no spark
    Check:
    1. spark plug
    2. ignition spark gap
    3. spark plug cap resistance
    4. ignition coil resistance
    5. pickup coil resistance
    6. source coil resistance
    7. main switch
    8. engine stop switch
    9. sidestand switch
    10.wiring (of the entire ignition system)
    Min.ignition spark gap
    6 mm (0.24 in)
    Spark plug cap resistance
    10 kΩ at 20 °C (68 °F)
    Primary coil resistance
    0.18 ~ 0.28 Ω at 20 °C (68 °F)
    Pickup coil resistance
    656 ~ 984 Ω at 20 °C (68 °F)
    (between white and red)
    Secondary coil resistance
    6.32 ~ 9.48 kΩ at 20 °C (68 °F)
    Source coil resistance
    624 ~ 936 Ω at 20 °C (68 °F)
    (between green and brown)
    Oct 2011
    Central Arkansas
    69
    1994. I looked at the manual and it isn't 12V on the ignition wire at coil. I was going to jump 12V to the coil and see if it would crank.
    There is a test procedure in the manual but I was being lazy looking for an easy way to diagnose.
  1. Pulser Coil
    By queenpdog in forum Technical Help
    Last Post: 05-22-2017, 01:12 PM
  2. Ignition Coil
    By BC4Lyphe in forum Technical Help
    Last Post: 04-02-2013, 08:24 AM
  3. 2010 pick up coil
    Last Post: 10-29-2012, 10:44 AM
  4. 2000 TW200 Stator and Coil
    By scott_whitman in forum TW200 Classifieds
    Last Post: 01-21-2012, 11:29 PM
  5. Pulser coil
    By SirSmighty in forum Technical Help
    Last Post: 10-06-2011, 02:42 PM
tw200 no spark from coil
