Hows the best way to oil the cables
Results 1 to 8 of 8
    Member brent morley's Avatar
    Feb 2012
    Dayton Tenn.
    57
    Hey guys just wondering what is the best way to oil the brake and clutch cables and how often.... thanks
    I got granny gear haha...
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by brent morley View Post
    I can't say this is the "best way" but it's the way I've done it since 1971. I have a tools similar to this http://www.ebay.com/itm/MOTORCYCLE-C...a47c33&vxp=mtr. I do it at least once a year, but I keep the bike under cover and generally don't ride it if it's raining - and it's dry much of the year here in CA so the cables don't generally have issues. If you thrash your bike in the mud and/or ride a lot in the rain, or wash the bike a lot, do it more often. You really can't overlube the cables.
    and here is how it's done:
    http://www.youtube.com/watch?v=TFMVlQRrBDE
    Ephrata, WA
    1,125
    I use one of those cable luber things too. Not the easiest thing to use, but it does work great. Lube your cables up as much as you want to. I probably do mine every oil change.
    1990 TW200
    The Southwest
    566
    The OEM cables are not lined with nylon?
    Feb 2012
    Dayton Tenn.
    57
    Thanks man, very helpful
    Apr 2012
    374
    My pleasure - gotta keep the rust away.
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    I am with that guy
    I thought all cables were lined but maybe some anti corrosion would be nice
    That is what WD40 is WD water displacement formula 40
    Member -Jake-'s Avatar
    Feb 2012
    81
    All I do is pull the cable off of the levers then shoot some liquid graphite down them and work it back and forth.
  1. aftermarket handlebars, throttle cables short, advice?
    By pushinluck in forum Performance and Customization
    Last Post: 02-18-2013, 09:21 AM
  2. longer cables?
    By Rhodetrip in forum Technical Help
    Last Post: 09-21-2011, 08:03 PM
  3. Misc. TW parts....carb, K&N, cables, CDI
    By adavis in forum TW200 Classifieds
    Last Post: 05-22-2011, 11:21 PM
