Clutch adjustment possible?
Results 1 to 6 of 6
    BC
    536
    Lately, I've been having a real tough time getting into Neutral.
    Even though my clutch is pulled in, the shifter doesn't want to move UP from first gear. Shifting isn't an issue while driving, only when standing still.
    Is there an adjustment that I can do?
    Visit my Blog...Hidden Content or my YouTube channel: Hidden Content
    Jun 2011
    Dothan, AL
    1,715
    I notice a big difference with the oil. It is much more difficult with 20-50, so I have been sticking with 10-40 and the transmission is much smoother altogether.
    2005 TW200 (SOLD)
    2013 DR650
    BC
    536
    I have used nothing but Mobil Racing 4T 10W-40 since the day I bought it and never had a problem with clutch or gears until now.
    I have over 25,000 miles.
    Jun 2011
    Dothan, AL
    1,715
    I think you can make some adjustments at the clutch perch as well as where the cable enters the engine case. Not sure about internally. I'm sure someone will be along soon with a better answer.
    2005 TW200 (SOLD)
    2013 DR650
    The Southwest
    566
    It may help for diagnosis: At what lever position does the clutch engage/disengage, i.e. all the in, all the way out or somewhere in between? And is this position different from where it used to be?
    BC
    536
    The clutch disengagement is near the end of travel (all the way out) as it has been since day one. The spring is still in place.
  1. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  2. Cam Chain Adjustment
    By Eyesell in forum Technical Help
    Last Post: 07-28-2012, 07:05 PM
  3. Valve adjustment
    By Scotto560 in forum Technical Help
    Last Post: 03-13-2012, 12:07 PM
  4. Clutch adjustment
    Last Post: 06-24-2011, 07:38 AM
  5. Pilot Jet adjustment
    By bruisr in forum Technical Help
    Last Post: 09-12-2010, 07:21 PM
tw200 clutch adjustment
