Carby Fuel discharge???
Results 1 to 10 of 13
Like Tree34Likes
Thread: Carby Fuel discharge???
    Senior Member jannaruto's Avatar
    May 2017
    363
    Hey guys, is normal that I find, if put my finger under, this hole a bit wet of fuel everytime?
    Ken and PlacerLode like this.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,406
    Quote Originally Posted by jannaruto View Post
    Not normal.
    That is the drain for the float bowl, but it is also the drain for the bowl overflow tube.
    Most likely there is a slight leak from the valve seat o-ring.
    You can temporarily stop it from dripping by turning off the petcock when not riding the bike.
    jb
    jtstdub, Ken, PlacerLode and 3 others like this.
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    793
    Only time I have a leak there is when Dub's on the trailer and going way up in elevation - I'll get some fuel dripping as the fuel expands in the bowl
    Mar 2015
    Ynys Môn
    4,631
    Lol – not for a bike at any rate
    I trust that this “hole” has a pipe attached, which should lead below the frame – some “wetness” can occur when she gets a bit excited, ridden hard etc – but a “constant leak” either means the float bowl isn’t sealing correctly, or your onto a winner
    As far as the bike is concerned, making sure the fuel is turned off at the tank when not in use is a good idea – everything else I’ll leave to your discretion …….
    - Hidden Content
    Jan 2015
    Fair Oaks, Calif
    503
    Gotta get that fixed. You can end up with gas in you oil. Check your oil level....
    Jim
    littletommy, PlacerLode and Ken like this.
    Skiing the slopes in Switzerland
    17,585
    Are you shutting off your petcock while trailering??
    Quote Originally Posted by Donzo View Post
    Ken likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Member westcoasting's Avatar
    May 2016
    76
    Carby?? What the heck is a Carby... sounds like the latest diet my daughter would be on!
    PlacerLode, Ken and grewen like this.
    Oct 2016
    NorCal
    793
    I didn't when we went to Sweet Water and had the dripping - I will from now on tho....if I remember.
    May 2017
    363
    Not constant at all, I never noticed actually a single drop even on the engine, it's only a bit wet that drain hole when i put finger under it, that's all, the tip of the finger gets slightly wet from fuel
    Yes I drive my bike pretty hard, like speeding, high rpm, I stress the bike a lot, oil is super fine, never a single problem related to it, aside a leak couple of weeks ago but that was solved with some gasket changes and also I did a change of oil 2 days ago (3000km reached with old oil)
    The drain screw is new and screwed in quite good (the screw that when unscrewed let the fuel pour out from the bowl)
    Apr 2012
    Out West
    3,063
    more than likely you need a new needle seat which I consider a routine maintenance item like an oil filter etc.
    If the needle seat is not shutting off fuel flow once the proper float level is achieved the fuel can rise above the bowl gasket and leak out (assumes a tired bowl gasket which is also common) depending on how much fuel the needle seat is allowing to pass the carby could overflow from the vent. The biggest risk of letting this go is that fuel can (and will) leak into the crankcase and dilute the oil which is obviously bad for lubrication but will quickly dissolve clutch plates leading to an early clutch failure and a nasty clean up job
    take a peak at your oil level and see if it's rising above the usual level and take a whif of your crankcase and see if you smell carby juice ie petrol
    Spend 50 bucks on (2) news needle seat kits and a bowl gasket and be sure to clean or replace your pilot jet while you're in there. Carry the spare )back up" set along with your spare spark plus etc in your tool kit for the next time you'll need it
    Partzilla charges the same shipping for one or two (or more) kits so it will lower your cost per kit by grabbing two
    "It's Like Warm Apple Pie"
  1. Replies: 7
    Last Post: 08-28-2016, 03:30 PM
  2. Carby that can take boost? what to use?
    By MIK20B in forum Performance and Customization
    Last Post: 09-16-2012, 05:30 AM
  3. Fuel
    By Gunner in forum Performance and Customization
    Last Post: 07-26-2012, 06:03 PM
  4. Battery discharge = dead tachometer
    Last Post: 06-11-2012, 07:43 AM
  5. The black carby
    By RobRz in forum Technical Help
    Last Post: 06-06-2012, 05:19 PM
