Where On The Swing Arm Should I Measure For Proper Chain Slack?
Results 1 to 10 of 12
Like Tree28Likes
Thread: Where On The Swing Arm Should I Measure For Proper Chain Slack?
    Junior Member ATTHECROSS's Avatar
    Sep 2017
    23
    Hello Everyone!
    Merry Christmas! The chain jumped off the rear sprocket of my TW. It was a bummer because it scuffed up some of the swing arm, etc. After it happened I noticed that the rear axle adjustment plate was set to different indicating numbers on each side. The drum brake side it was set to "3" while the chain side was set to "2". That is the only reason I can assume it jumped. But my question is, where is the correct spot on the swing arm that I should measure for chain slack at? If anyone can provide a picture that would be much appreciated. The Yamaha owners manual does not show specifically where I should measure at. I have attached the manual image to this post. Also I know what the manual recommends for chain slack. Is there any specific measurements that you all prefer? Thanks for the help in advance. I don't want this to happen again. IMG_0816.PNG
    littletommy likes this.
    Apr 2014
    Dryden NY
    6,343
    The simple answer is, as close to midway between the front and rear sprocket as possible. Remember that you are not building a Swiss watch. Close is close enough.
    Tom
    Senior Member Howsbentley's Avatar
    Jan 2013
    Memphis,Tn
    209
    Here’s a good visual reference -
    #GYG
    '13 TW200
    A.T.
    Elvesus, littletommy and maddawgj like this.
    Sep 2017
    23
    Thank you both! I will definitely check out the video ASAP! Much appreciate the help! Take care!
    littletommy and Howsbentley like this.
    6,999
    A little to loose is much much better than a little to tight.
    littletommy, 2scoops and maddawgj like this.
    Sep 2017
    23
    Thanks for the advice elime.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,411
    3 on one side and 2 on the other is a huge difference!! how did it get that far out? i have never really measured with anything other than my toe. with the snails, the chain is going to be either too tight or what is going to look like too loose, and like Elime says, too loose is the better of the two
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    6,999
    The chain is tightest when the front sprocket drive shaft, the swing arm pivot bolt, and the rear axle are in a straight line. Adjust your chain when this happens. When not in a straight line, as it is in the picture, the chain will be looser. Don't worry about it being to loose as long it is not to tight when those three points line up.
    littletommy and Fred like this.
    Hailey, ID
    3,405
    Quote Originally Posted by grewen View Post
    BOTH of my TW's need exactly that much differential to have the axle parallel to the swing arm hinge bolt! This is apparently quite common, and the only way to be certain that the axle and swing arm hinge are parallel is to measure the center to center distance from swing arm bolt to axle bolt on both sides. It doesn't matter what the value is, just that they are equal.
    The way I found this out was when I installed the dual sprocket and noted that the outside of the OEM sprocket was worn a lot and the inside not at all. There is a photo of the OEM sprocket wear on my post on page 8 of the Dual Sprocket sticky. There was NO indication in handling that it wasn't OK, and I imagine that 98% of the TW's live out their lives with non parallel axles. Not mine.... My right side snail has to be three notches less than the left side, which is 3 to 2, 8 to 7, 4+1 to 3+1, or whatever.
    Want to find out? Take any piece of wire, make a sharp 90 degree bend in one end, center that on the axle bolt and put your thumbnail on the other end at center of the swing arm bolt. Make a mark with needlenoses or marker, then transfer to the other side and remeasure. Do it several times. On the right side you have to sneak the wire behind the rear brake mechanism to avoid too much of a bend throwing off the measurement. I figured it was an anomaly until I measured the brand new 2018 and it was exactly the same off.
    Rear sprocket wear at 11,000 miles was equal on both sides. That tells me the rear tire and axle are running exactly perpendicular to the chain, and the sprocket is perfectly lined up with the chain, like they should be.
    Oh, and I usually set my slack at between 1.5 and 2 inches and don't worry about it until it gets to be more than 2.4 inches. You will feel a bit of jerkiness on the lower gear shifts at that value.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    6,999
    Very interesting. A quick check with a piece of coat hanger wire and both my TW's were nearly equal on both sides. not exact but almost.
    I did notice when I had dual sprockets one side of the sprocket was worn heavily but I figured that was to chain misalignment.
    How would one check the engine sprocket to the rear wheel sprocket? Any ideas?
    One thing I do is make the axle nut "snug", then I take a piece of wood and place it against the axle and tap it with a hammer driving the axle forward so the snail is tight against the pin, then I torque the axle nut to spec. It often looks fine but with the tap of the hammer I can see it move forward. This happens every time I R&R the rear wheel.
    maddawgj and littletommy like this.
  1. Longer chain for 8" swing arm?
    By TWBUSHMAN in forum Technical Help
    Last Post: 05-13-2017, 02:04 PM
  2. Wtb Swing arm pivot chain guard
    By flyhunter3825 in forum TW200 Classifieds
    Last Post: 07-02-2015, 09:13 PM
  3. Extended swing arm ,chain & break rod extender
    By Old man in forum General Discussion
    Last Post: 03-04-2014, 07:19 PM
  4. Chain slack measurement!?
    By kj7687 in forum Technical Help
    Last Post: 05-16-2011, 09:16 AM
  5. How much chain slack?
    Last Post: 11-17-2010, 08:24 PM
